C-4 vs C-6
I have searched for the article and can't find it now, I have found parts of the results charts, and quotes from the article but not the whole tamale.
Racers like the powergluide and the C4 because they are lighter than the others and can be built to handle big HP.
As I recall the AOD ate HP
I'm going with a built C4 behind my Flatmotor for weight savings and to handle the massive horsepower that will be made, for the Three-0-Two, a stock C4 or C6 will easily handle all that can be wrung out of it.
on
I've got a dumb question ??? seem like years ago when I was playing with small blocks...302 and 351Ws in a 72 f-100 I remember the C-4 being the only (of the two) that would bolt up to a small block... does a c-6 have the same bolt pattern as a c-4 or doyou need one of them a-daptor kits or sumthin ???
learning with every breath..
john
john
Originally Posted by jniolon
I've got a dumb question does a c-6 have the same bolt pattern as a c-4 ?
john
john
Short answer; yup, they put C6's behind many Cleveland 351s and lots of vans and trucks with 351W had C6's. Funny thing is that even though the C6 is a heavy duty transmission, it's not very popular behind small blocks. Too many other choices (C4, AOD).
john
john
Sometimes Ya need an a-daptor, Sometimes a sumtin will work, an othertimes, well------------------------
on
60 HP ??? BB guys don't worry 'bout no stinkin 60 HP... we lose more than that when a plug wire goes bad !!!
see... I'm still learning !!!
later
john
Some basic source info
Engine Trans Type
122L4-20-C4
140L4-23-C4
171V6-28-C4
200L6-33-C4
240L6-C4
250L6-C4
289V8-C4
300L6-C4
302V8-50-C4
351MV8-57-C4 Big Block Bell Housing Pattern
351WV8-57-C4
I would avoid the early Six Cylinder Trannys
Some of the Early models had a Smaller input shaft – If necessary they can be changed.
For more indepth hash of the C4 go to: http://www.mustangcentral.net/tech/c4.html
Engine Trans Type
122L4-20-C4
140L4-23-C4
171V6-28-C4
200L6-33-C4
240L6-C4
250L6-C4
289V8-C4
300L6-C4
302V8-50-C4
351WV8-57-C4
SpencerS
07-17-2014 08:51 PM
1972RedNeck
04-16-2012 08:51 AM
banjopicker66
05-23-2004 06:17 PM
