5.4 performance
Old 04-03-2004, 10:23 AM
skitzobraindoctr's Avatar
skitzobraindoctr
skitzobraindoctr is offline
5.4 performance
what r some of the best performance mods for the 5.4 v8? my truck is a 1998 f250 light duty 4x4.
Old 04-03-2004, 09:12 PM
olie's Avatar
olie
olie is offline
Mods
I have the 5.4L in my '97 and have seen performance increases by adding the following: K&N air filter with cold air intake, Gibson split rear high flow exhaust, B&M Shift improver kit, new dual platinum plugs. My next mod will be the Super Tuner programmer to reprogram the ECM. In the past I have always started with these mods before moving onto the motor, and as you have probably already figured out, the 5.4L is a to work on. I lucked out by adding a 3" body lift so the motor is easier to get to. Try more air, let it breathe better and you will start to notice the difference. High octane gasoline always helps. Then, when you feel adventurous, clean the intake, i.e. throttle body, idle control, etc and it will run better. Hope this helps!!
P.S. you can get teh cold air intake without buying the whole system, it's a pretty easy modification to your intake with a K&N filter. Let me know if you're interested and I will e-mail you the link on how-to.
Old 04-03-2004, 09:14 PM
skitzobraindoctr
i am very intrested in the mod.
Old 04-04-2004, 03:19 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Here ya go.
Pretty self-explainatory...
http://www.clubfte.com/users/monsta/airboxmod.html
Old 04-04-2004, 12:08 PM
CPerry's Avatar
CPerry
CPerry is offline
Ken, I live in the other Kailua :-)
Interesting modification but won't it just suck hot air in to the motor?
Old 04-06-2004, 01:46 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Hey! No kiddin'! Howzit, bra!
__________________________
Sure it will! But just how hot will hte air be inthere when you're travelling down the highway at 60mph?
Anyway...that mod is done on a Super Duty which, coupled with another mod (The ZooDad Mod), is what refer to as the poor man's FIPK.
Old 04-06-2004, 10:01 AM
fordborn's Avatar
fordborn
fordborn is offline
So far I have added a cold air intake and a hypertech programmer Supertuner. It has given increased performance and better shift points. As an added suprise my fuel milage actually went up by 2mpg. Next will be adding an exhaust system.
Dodge no more
1999 to 2016 Super Duty
36
08-13-2017 07:56 PM
BIGBAD250
02-15-2010 01:31 AM
havi
Modular V8 (4.6L, 5.4L)
20
08-27-2009 04:56 PM
wgw
09-04-2002 06:57 PM
redranger1
08-07-2002 10:53 PM
Quick Reply: 5.4 performance
