hard starting
hard starting
first let me say thanks in advance.i have a 99 ford e350 van with a v10 engine. the van has 99 thousand miles i had to replace the engine at 78 thousand.my problem is sometimes when i try to start my van it justs cranks and wont start until i hold the throttle wide open then it starts up.this will happen if the engine is hot or cold.
It's easy really just hard to reach. 2 bolts(which you don't want to drop) It's on the back of the trottle body facing the firewall. Remove the 1" dia hose, wire harness, 2 bolts. Watch out for the gasket too. I bought a new one just in case. You can follow the hoses off the intake to find it.
doyawanna
11-05-2016 08:13 PM
andrewzx92000
11-29-2015 07:06 AM
videopro192
15
02-01-2010 03:02 PM
