Oil in coolant..but no coolant in oil
01-22-2006, 08:02 PM
on
I have oil in my coolant...but no coolant in my oil???? I'm stumped. Any suggestions.
01-22-2006, 08:21 PM
on
Head gasket...likely...what motor? What is the exhaust like?? thick....smell sweet?
01-22-2006, 09:19 PM
run a compress and leak down test...will tell you which side and which hole....
01-22-2006, 11:02 PM
Quote:
PIA, but the only way to find it. Unless someone has been dumping Oil in the overflow res instead of the oil fill.
01-22-2006, 11:09 PM
also look for tiny pin bubbles in coolant in radiator fill neck while warm and running...
not champagne
may also show up on discolored plugs but not guarenteed
01-23-2006, 12:52 AM
on
May be it is ATF.... I had this probleme. The leakage was inside the radiator....
JamesMcMn
10-17-2016 10:47 PM
Moonpie6899
05-22-2016 10:59 PM
yz400f
12-01-2009 02:08 PM
eco
21
04-01-2007 10:32 PM
cabinetmaker00
Competition
03-23-2007 06:59 AM
