1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Squeak, Squeak, Squeak
Old 02-15-2004, 04:42 PM
coglesby's Avatar
coglesby
coglesby is offline
I have 2003 SD 4X4 CC and I am hearing squeak, squeak squeak that seems to be speed related (not engine RPM related). Truck only has 10000 miles. Anyone know what this could be?
Old 02-15-2004, 05:20 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
The front inner seals can make a racket. Is it just in 4wd???
Maybe not huh I see you live in texas. Also the front springs can make alot of noise when you go over small bumps, I think there is a TSB on that one..
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Check u joints first.
What motor and tranny?
Old 02-16-2004, 08:18 PM
coglesby's Avatar
coglesby
coglesby is offline
6.0L PSD with Torqueshift Tranny
Old 07-13-2004, 08:28 AM
cfd29's Avatar
cfd29
cfd29 is offline
I have the same problem, very squeaky front springs. It isnt the drive train, because you can make it squeak by jumping up and down on the running board while parked
There is a Ford TSB on it, but I can't get anyone at the dealer to tell me the right place to lubricate.. They just say, "Yea there is a bulletin on that", When you ask them what to do, they just say "it is real hard to stop"
Any one have any ideas??
Old 11-29-2004, 06:27 PM
BStinson's Avatar
BStinson
BStinson is offline
Mine does the same thing ('03 F250 FWD V10 CC). Starts about 7-8 mph and gets faster with speed. Sometimes stops at 50-60 mph, sometimes doesn't. I put it on the lift and let it idle in drive. It seems to be coming from the drive shaft. I have read a few threads on some sort of mis-alignment in the center drive shaft bearing on '03 models made early in the production year (which mine was). Any other info. would be much appreciated.
Old 11-29-2004, 06:41 PM
Bear Hunter's Avatar
Bear Hunter
Bear Hunter is offline
Check your tailgate...I'm not kidding. Walk behind your truck and push up and down on your bumper. I had a squeak I couldn't figure out...thought it could be bearings, etc. Until I drove with the rear window open and figured it was coming from the rear end. Pushed up and down on the bumper and low and behold...squeaky tailgate. Shot of WD-40 fixed it and it hasn't returned since.
Old 11-30-2004, 11:32 PM
bdcrecy's Avatar
bdcrecy
bdcrecy is offline
Same noise...
My '03 CC FX4 makes the same noise. Not springs, it's definitely speed related and seems to come from rear of truck. I think it's the shaft or rt. rear wheel? Any other ideas? Is there a TSB on it?
Old 12-01-2004, 06:20 AM
BStinson's Avatar
BStinson
BStinson is offline
Red face
I tried checking the tailgate - I'm not that lucky - no squeak there.
Ford ordered a center carrier bearing for my drive shaft and I am putting it in this evening. I'll post results from this attempted fix.
Old 12-01-2004, 06:29 AM
03F-250V10's Avatar
03F-250V10
03F-250V10 is offline
I had a problem that seems related. It turned out it was the carrier bearing in the rear drive shaft. There is a TSB on it and the dealer gladly replaced it. I hope this helps.
Old 12-01-2004, 08:52 PM
bdcrecy's Avatar
bdcrecy
bdcrecy is offline
Rear wheel...
I really think it's my rt. rear wheel because of the timing of the rotation. The shaft moves much faster than the rotating noise...
What could cause a wheel to squeak like that
Old 12-02-2004, 06:08 AM
BStinson's Avatar
BStinson
BStinson is offline
Thumbs up
I know what you mean. The squeak doesn't cycle as fast as the drive shaft turns. That makes is confusing to diagnose. Last night, I replaced my center carrier bearing and the squeak stopped! Cost me $80 for the part at Ford and about two hours of time for the fix. Unfortunately, I am having some new rattle noise, which I hope is not related to way I installed the carrier bearing.
Old 12-02-2004, 06:16 AM
03F-250V10's Avatar
03F-250V10
Glad to hear that it was the carrier bearing. On mine it almost sounded like a siren in a distance. The first time I heard it I was checking my mirrors to see what was coming behind me... Anyway glad that helped.
broncoderek
10-28-2014 02:54 PM
HighRiskJob
1997 - 2003 F150
09-16-2014 09:22 AM
WickedSharp
01-13-2011 09:10 PM
Bonkrr
1997 - 2003 F150
09-14-2009 10:19 PM
maxtruck00
05-22-2009 12:52 PM
Quick Reply: Squeak, Squeak, Squeak
