Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-14-2004, 08:35 PM
4.2flybyu is starting off with a positive reputation.
exhaust? and Suspension?
I had two questions for you guys. I have a 99 f-150 reg cab 4.2. On their is a flowmaster 40 series with stock tail pipes. I was looking for a louder sound and some more power so i was going to get another flowmaster and run tru duals. Will this make it louder, and will i be releasing too much backpressure for the 4.2 cus i already have 2.5 inch pipes and i heard u need some backpressure. How much diffrence will the duals make in power and gas milege?
And my suspension question for you is---- I have shackles on my truck right now and it still doesnt sit level the back sits about an inch higher. My truck also has a pretty hard suspension that doesnt give much. I want my truck to ride softer and sit level about 2 inches lower without having to worry bottoming out or going slow into driveways and such. Can this be done? I was thinking about doing 2'' drop coils in the front and hangers in the back. I was also thinking about taking out a leaf spring out in the back to make it sit level. Any suggestions or comments
  #2 (permalink)
Old 02-14-2004, 08:39 PM
o and i have a mac intake that i enjoy a lot.
  #3 (permalink)
Old 02-15-2004, 10:10 AM
true4.2 is starting off with a positive reputation.
Yes, getting true duals will give you more power than stock. Go for it. You said you have the intake, so that should make up for any backpressure issues.
If I were you I'd order a 2/4 drop from belltech, and install it. It's not low enough that it will bring up clearance issues, and it levels out your truck and makes it look really good.
__________________
--Joseph--
'08 F350 6.4L
Hot Shot Hauling Truck
  #4 (permalink)
Old 02-15-2004, 08:09 PM
thanks but im not possitive a 2/4 would level it out becuase i alredy have shackles on or a 0/2 and its not level. i hear you are looking a a 2/4 yourself let me know how it goes.
  #5 (permalink)
Old 02-16-2004, 08:15 PM
SkinnyNate is starting off with a positive reputation.
I'm not to sure duals would be a good idea. I opened mine up to much before and lost a lot of low end torque. I did however gain a pretty good amount of hi end power though. So I guess its what you are looking for. I have a SC now and am still a little skeptical about going dual. The MAC guy agreed with me and suggested a single. But I am going to dump it to. So thats a little less back pressure to. I still may go dual but I'm moving a lot more air.
My suggestion is learn to weld! Then its cheap to try a few different combos. to see what works best. (besides once you learn to weld you can do any thing and for ALOT cheaper.
Oh, and from the factory I belive its 2 1/2" higher in the back. Thats what mine was. (supercab) Yours may be a little different with the short wheel base.
  #6 (permalink)
Old 02-16-2004, 08:21 PM
thanks, my friend is going to weld it for me i think ill go ahead and try it. ill let you know.
  #7 (permalink)
Old 02-17-2004, 12:31 AM
NTheCrux is starting off with a positive reputation.
I have a 2/4 ground force drop on my 03 and it is level. I bought mine as a kit but I've heard of people buying just the pieces they need. I was very happy with the quality of parts and cusomer service with ground force. The truck handles much better than stock and I have'nt had any bottoming out issues.
  #8 (permalink)
Old 02-17-2004, 02:55 PM
Busa01's Avatar
Busa01 is starting off with a positive reputation.
If you want to just level it, you can get a front leveling kit for real cheap. It consists of 2" rubber spring fitting that mounts on top of your front springs. They work really well and make your truck look nice.
Unless your really thinking of dropping the whole truck, I think this is the best way to go.
tom
__________________
Stop pointing at me!!
  #9 (permalink)
Old 02-17-2004, 02:58 PM
Busa01's Avatar
Here's a picture of it sitting nice and level, before I installed the lift kit.
http://www.ford-trucks.com/user_gall...=33070&width=0
__________________
  #10 (permalink)
Old 02-17-2004, 04:21 PM
On the true duals: Yes, true duals make you loose low end torque. This is where the intake helps you back out of that 'slump.' Also, a chip would definately fix your torque problem.
__________________
--Joseph--
'08 F350 6.4L
  #11 (permalink)
Old 02-17-2004, 08:52 PM
on the ground force drop kit did it come with the gas shocks in the back
thanks
  #12 (permalink)
Old 02-18-2004, 01:45 PM
The ground force kit I have came with gas shocks front and rear, springs, hangers, and shackles. The kit was really complete except I would of liked some shock boots just to dress things up a bit. Maybe I'm just picky. I will try to get some pics up of my truck this weekend so you can see the after.
NTHECRUX
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
