2.9 with black smoke pouring from exhaust
I got a 1987 Ranger that really acts up and is extremely hard on gas. When acting up it just pours black smoke from the exhaust, I think it's overfuelling.
I have put the folowing parts on this year and still can't figure it out.
cap, rotor, plugs and wires
O2 sensor (twice)
pressure regulator
TPS
MAP
temp sensor
I've also checked all vacumm lines and ground connections.
Any thoughts would be helpfull.
O2 sensor (twice)
pressure regulator
TPS
MAP
temp sensor
ibugsy...if you figure it out, please post it here, cause mine is doing the same exact thing! I'm completely stumped. A guy I work with told me to try the "either" test, by spraying either around the motor while running to see if there's a vacuum leak. I changed all the parts you did, still running like crap. Maybe it's electrical? No check engine light either...
The vacuum line running down to the tranny is metal around the exhaust, and I think the heat sheild above the cat. conv. rubbed a hole in it...hence vacuum leak. I replaced the whole line all the way down, runs like a top now...Happy as heck now, that darn thing had me stumped me for 2 weeks, and it ran horrible. Drove it back and forth to work today,(30 miles), ran like an almost-new truck!
Redneckfordf2502002
35
01-14-2016 07:36 AM
67speeda
48
07-04-2015 06:47 PM
FightinTxAg
19
04-24-2015 07:29 AM
