clutch start switch
clutch start switch
I am unable to find the clutch start switch in my truck = i know it their because i have to press the clutch to start= it not hooked to the clutch pedel so where is it= can't find it under truck either= anyone have any idea. i have the ford shop manual and can't find it in that either.
The picture didn't make it through but it looks like it's up where the master cylinder push rod is, you should see a wiring harness and connector where the pushrod is. This should be it.
REMOVAL AND INSTALLATION
Clutch Pedal Position (CPP) Switch
Removal
Disconnect the wiring harness from clutch pedal position switch (CPP) (11A152).
Pull down on orientation clip to separate from switch tab.
Rotate clutch pedal position switch one-half turn to expose plastic retainer.
Push switch tabs together and slide retainer rearward and separate from clutch pedal position switch.
Remove clutch pedal position switch from clutch master cylinder (7A543) push rod.
Installation
Reverse the removal procedure.
Item Part Number Description
1 — Switch Tab (Part of 664D0 Clutch Pedal Position Switch)
2 — Plastic Retainer
3 — Orientation Clip
(Part of 7A543 Clutch
Master Cylinder)
4 — Push Rod (Part of 7A543 Clutch Master Cylinder)
5 11A152 Clutch Pedal Position Switch
6 — Wiring Harness (Part of 14401 Main Wiring)
7 — Pin (Part of 664D0 Clutch Pedal Position Switch)
8 7A543 Clutch Master Cylinder
Removal
Installation
Master Cylinder)
1980 F100 3onthetree
07-01-2015 12:14 AM
DanielT28
07-09-2014 08:48 PM
86ford302help
12-04-2013 07:43 PM
4inchlovin
02-24-2012 05:06 PM
