1978 - 1996 Big Bronco
Big Rig Air Horns
Old 12-29-2003, 10:31 AM
89Bronco_EddieBauer's Avatar
89Bronco_EddieBauer
89Bronco_EddieBauer is offline
Big Rig Air Horns
Whats up Guys?
Does any one have air horns in their rig? Im lloking for a set of two that can be mounted on the roof and have the deep sound of a true rig. Not the corny ones from Autozone. If you do have the horns im looking for, id like to know where you got them and how much you paid...
Some pics of your trucks with the air horms mounted would be great!
Old 12-29-2003, 10:48 AM
mustangman65_79's Avatar
mustangman65_79
mustangman65_79 is offline
best bet, talk to a semi shop, they d dell them, but then u need a big air tank and compresser
Old 12-29-2003, 12:29 PM
Stokes's Avatar
Stokes
Stokes is offline
EBAY!! im also lookin for the horns off of a Peterbuilt.
Old 12-29-2003, 02:44 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Go to one of the local full service truck stops off the highway in your area. I got a dual bugle set for my truck for $70 including the little electric mini compressor that went with em. I mounted mine under the hood but OH what a kick! Scare the hell out of anyone if they are close enough. hehe
Didnt require a fill compressor and they are a hell of alot better than the Autozone garbage units.
Old 12-29-2003, 02:52 PM
89Bronco_EddieBauer
Nice. Im in NYC, but Ill find one of those shops. Itll be great to use on eof those in Times Square during rush hour.
Old 09-05-2004, 01:13 AM
MARINO90's Avatar
MARINO90
MARINO90 is offline
Thumbs up Air Horns,air Horns
air horns,air horns. thats how i started and became one of the biggest project in my 1990 bronco i started with normal 12v. air horns and whent all the way to tractor-trailer air horns.then i found out the bigger the horn the more air you need so a extra air tank came in to picture it work okey but 12v. comprs. gets red hot with extra air tank after the secound 12v. air comprs. i burn-out. i started thinking and i took the air horn project to the limite the idea came one day that i was stop at R/R crossing i live in miami and yes guys we do get every now and then a train to go by. so i started looking around and found a set of TRAIN HORNS a set three BIG horns so i got two sets 6 BIG TRAIN HORNS i got a 3000 watt 12v.convet.to run a1/2 hp 115v. air comprs. with a three gl.tank got and old scuba tank painted to mach the bronco and became and extra air tank for the system. all air lines are 3/8 from compres. to horns to land yard. so guys emagine what 150 P.S.I. can do to your ears and neck hairs....
so you see air horns to BIG TRAIN HORNS.........................
Ford SD
09-29-2015 01:02 PM
snaponprofile
52
04-27-2011 04:42 PM
airraid
Electrical Systems/Wiring
01-08-2007 11:07 AM
wolf3891
12-29-2000 07:45 AM
lee
10-30-2000 12:57 AM
Quick Reply: Big Rig Air Horns
