Air horn wiring
Air horn wiring
I finally got around to making a proper schematic of my air horn wiring, including the Highway / City toggle switch that determines whether the steering wheel horn button blows the stock electric horns or the air horns. My diagram includes 4 selector toggles, but this is because I'm putting together a setup to demonstrate multiple horn and siren devices. Normally, you would have only one air horn solenoid connected to the 30A relay.
The schematic:
Below is what the panel on the dash really looks like. I cut a piece of aluminum flat stock (what auto customizers mistakenly refer to as "billet") and polished it to make a simple panel to cover the useless slot in my aftermarket stereo adapter bracket:
Compressor and horn in the bed. Compressor is oversized (30 gal) because I test some large horns. For regular truck air horns you only need about 5 gallons:
The schematic:
Here's a follow up, the horn is now operational and I made a test video. Because my camera has automatic gain control you can't tell the relative loudness of the stock horns vs air horns, but the length of the echos is a clue. I have to wear the earmuffs in order to honk the horns while I'm standing next to the truck :-)
<object height="350" width="425">
<embed src="http://www.youtube.com/v/rjR5K_Fb6r4" type="application/x-shockwave-flash" wmode="transparent" height="350" width="425"></object>
F1Hunter
15
12-20-2015 10:16 AM
atomicjoe23
02-20-2009 09:33 PM
