Engine bay cleaning ? (so it will start too!)
Old 11-10-2003, 10:40 PM
TodzY2KExpy's Avatar
TodzY2KExpy
TodzY2KExpy is offline
Unhappy Engine bay cleaning ? (so it will start too!)
What is the best method to clean the engine and engine bay?
Car Wash Spray, Gunk, Problems, cautions?
PLMK
2000 Expedition
Old 11-11-2003, 11:21 AM
MrBSS's Avatar
MrBSS
MrBSS is offline
I like to do it on a sunny summer day. It helps if the engine is warm. Disconnect the battery and protect the electrical components. Use a low pressure degreaser in a hand spray bottle and rinse with a light spray from the hose nozzle. Blow out any areas of accumulated water, particularly areas with secondary voltage,ie., spark plugs, coils (especially COP's), ignition wires (if applicable).
Then let it sit in the sun with the hood up for as long as possible before reconnecting the battery. The main thing you need to avoid is getting/leaving water where it can short things out. That's why I would stay away from any high pressure, even though it makes it harder to do a real thorough job. I would accept that you may not be able to eat off your engine!
PS: After disconnecting your battery, the engine may run funny for a while until the computer re-learns its parameters. Don't let this concern you; it'll be OK shortly.
Old 11-11-2003, 01:00 PM
WillieWildcat's Avatar
WillieWildcat
WillieWildcat is offline
Ooohhh, I am not sure I would spray water on my engine. Just not a fan of getting that much water around all of the electronic components that make up our engines nowadays. If you must, good luck and seal off everything you can.
rat95dyna
07-06-2014 01:16 AM
tseng19
2004 - 2008 F150
03-27-2012 07:33 AM
EXbowtieguy
10-25-2011 11:16 AM
tr0y
1999 to 2016 Super Duty
03-02-2008 10:49 AM
Cyanide96VR6
Bronco II
10-12-2003 08:51 PM
Quick Reply: Engine bay cleaning ? (so it will start too!)
