96 F150 dual gas tanks,front pumps to rear, rear not working.
Old 10-25-2003, 07:59 PM
Mechineed's Avatar
Mechineed
Mechineed is offline
Just bought my new used Ford. The front gas tank pumps gas to the rear and truck won't run off rear tank. Wheres the switch or switching valve supposed to be ? Can't find. Mechineed.
Old 10-25-2003, 09:56 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
There is no switching valve, all the switching is done by the two in-tank pumps themselves. There is a valve on each pump that opens when that pump is energized for the fuel to return to that tank. Sometimes when a pump goes bad this valve sticks open. It sounds like your rear pump is bad. So when your front pump is running, fuel is able to go into the rear tank also.
Old 10-26-2003, 01:29 PM
Mechineed's Avatar
Mechineed
Thanks for the info. Already pulled pump out of rear tank. Wondering about cost of new one. Mechineed
Old 10-27-2003, 08:48 PM
Kostiuk's Avatar
Kostiuk
Kostiuk is offline
My 96 does this also. There is a recall for this problem for a variety of years but not for my truck. I called Ford and the lady I talked to said if they get enough complaints they may expand the recall. If anybody else is having this problem please call Ford. It sure seems to me they should fix this.
Old 10-27-2003, 10:29 PM
marragtop's Avatar
marragtop
marragtop is offline
I'm not sure you can buy just the pump. You may have to buy the whole assembly. If so, figure about $130 for Autozone.
mike L
39
11-23-2014 09:33 AM
wattspd
10-11-2014 06:40 PM
fightlivefree
09-17-2014 09:52 AM
tkisling
12-25-2013 09:47 AM
regbl10
03-09-2012 01:07 PM
Quick Reply: 96 F150 dual gas tanks,front pumps to rear, rear not working.
