1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Reverse Sensor Disable
Old 10-09-2003, 11:54 PM
Redshift's Avatar
Redshift
Redshift is offline
I searched the forum and did not find this answer--sorry if
I missed it as I am a new member.
Does anyone know how to disable the reverse sensor on a
F350 superduty? The manual says pushing the disable
button once will keep it disabled until you turn the key again.
My dealer has confirmed that this is a misprint - it resets
every time you go into reverse. I have a truck camper
installed and the sensor alarm goes every time I go into
reverse.
Dealer was concerned about upsetting computer settings if
sensors were just unplugged. He suggested taping the
button down (yuk) - but this doesn't work either -- it is
still reset every time you go into reverse.
Thanks a lot for the Help
Steve
Old 10-10-2003, 08:39 AM
Kraut's Avatar
Kraut
Kraut is offline
Fuse??????
Wire Cutters???????
Man is that a whoops.........a slide in camper on a pick-up (go figure), and the sensors on the rear bumper......another engineering feat.
Gotta admit though, that didn't occur to me either until I read this post.
Seriously....the only thing I can think of:
1. If that system is fused by itself (I can't imaginge that it is, but anyway), cut the wire near the fuse panel feeding hat fuse, put an on/off switch in line, hide, or install the switch somewhere where it looks good, and that would do it.
2. If the system has its own relay, see number 1 and do the same thing with the switching cirquit (not the load side) side of the relay.
IT's a pain in the I know, but a good set of wiring schematics would help this effort.
Damn.....never thought of this problem....
Old 10-11-2003, 03:07 PM
Gordondavis's Avatar
Gordondavis
Gordondavis is offline
I like Krauts idea of installing a switch in the reverse input line ,this will allow you to use the system when camper is not on the truck.Another solution is to relocate the sensors so they do not pick up the overhang of the camper,thus allowing the system to be used with the camper loaded.
Old 10-12-2003, 03:23 AM
haroutd's Avatar
haroutd
haroutd is offline
Location: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Relocating the sensors doesn't seem too doable, as you will have holes in the bumper where the sensors previously resided. Best solution I can come up with has already been suggested -- trace the wires back to a convenient location where you can splice a switch.
Old 10-12-2003, 12:09 PM
Gordondavis
A simple plastic filler cap or a steel knockout filler is an easy fix to the hole PROBLEM.What I did with my wifes truck was install additional reverse lights in the sensor location (she did not like the alarm so it was removed)
HouseOPain
1997-2006 Expedition & Navigator
01-20-2010 08:48 PM
ruschejj
12-24-2009 05:34 PM
ParaGoon
06-29-2006 09:14 PM
jdadamsjr
18
10-06-2004 11:53 AM
Quick Reply: Reverse Sensor Disable
