Hood Scoop
Hood Scoop
I have been desperately trying to locate a hood scoop for my 58. When I say hood scoop I am referring to the super-duty scoop that could be found on the 57-60 F-600 and up. I scoured E-bay, and spent many a happy hour in many junkyards and farmers fields, all to no avail.
I was wondering if anyone knew if someone makes these, or one that is very close to this design.
I tried to talk myself out of one, but after seeing the 57 in street rod builder (current issue), I realise that it is the look to finish off my truck.
Any help with options would be appreciated.
Thanks to all
Bulldog
Thanks to all
Bulldog
Hood Scoop
Bulldog,
I've been there too.... "I'll just be a minute, rest of the truck's around here in pieces, (an hour later) where's the **** hood!!!??".....gotta remember that people been hot roddin' these trucks for over 30 years, and plenty of scroungers have been over the same turf you're workin' now.
The closest thing I've come up with is the plain jane '58 hood scoop as in this photo:
Close but no cigar...
Still lookin' too.
Brett
Still lookin' too.
Brett
Hood Scoop
These things are hard to come by, I have had people with cash in hand trying to buy mine off of my truck. Summer before last I saw 3 to 4 of them at swap meets. I should have bought them if I would have known people would have wanted them. If I see any I will buy them the first one is already spoken for. But if I find any more I will let you know.
Hood Scoop
Hi BullDog58,
Over time, I've seen a lot of hood scoops on e-bay that appear to be extremely close in appearance to them. I don't how close they are dimensionally though.
They are always listed as "Pontiac Super Duty" hood scoops, and are supposedly used for racing (just about every one I've seen listed says that).
Most of the ones that I've seen have a chrome grille insert on the front instead of painted.
There's one listed now if you want to see for yourself. It is listed as item number 2432835823.
on
Hood Scoop
M.4S.F.
That would be most kind of you!
Please let me know when one other than the first spoken for is found.
Thank'ee
Colonle Flashman
Thank'ee
Colonle Flashman
Originally posted by mr4speedford
Would a 55-57 T-bird scoop look close? I keep hearing about this 57 in street rod builder, anybody got pics? I'm always on the look out for one of those hoods, I'll let you know if I come across one. -4speed
Hood Scoop
I appreciate the help. I thought about the T-bird scoop, but we did some test fitting and the look was not what I wanted.
Kenny I will check out the auction, thank you.
If I get one I will let everyone know, but if someone finds one please let me know.
Once again thanks alot. Hopefully I will get one soon.
Hood Scoop
Just for information I found the following website that speaks to the pontiac use of the hood scoops:
http://www.diecastmuscle.com/store/HI50150
I have checked the information and it is accurate. Here is the text incase the website does not come up.
"The original Super Duty 421 Lemans Tempests were Pontiac factory-built drag race-only coupes and station wagons, designed to combat other factory lightweights that had a weight advantage over the big Super Duty Catalinas. One "mule" car was built as a Tempest coupe in Silvermist Metallic and Blue interior, which was the testbed for the series. Eventually six Lemans-badged coupes were built, along with six Tempest station wagons in Cameo White with blue interiors. All sported deceiving 326 V-8 emblems, cleverly hiding the 421 cubic inch monster lurking under the hood.
In addition to the 421 engines, the Super Duty Lemans Tempests featured aluminum front sheetmetal, aluminum bumpers and a unique clutch-operated 4-speed transaxle. This transaxle arrangement placed more weight over the rear tires and allowed clutchless shifting, much like modern drag racing transmissions. Special parts on the 421 SD's included dual 4-barrel carbs mounted on the massive "bath tub" intake manifold, sealed aluminum cross-flow radiator with special overflow tank, and factory exhaust dumps. Other features included heater delete plates on the firewall, trunk mounted battery, special "black box" access door to the transaxle and clutch assembly, and hood scoop lifted from a competitor's medium duty truck line and given a Pontiac part number for the SD project.
The Super Duty Tempests were built over the Christmas holiday of 1962 and delivered just prior to the GM corporate racing ban of Jan 23, 1963. Pontiac abandoned factory-sponsored racing shortly thereafter, but not before making legends out of the drivers such as Arnie "Farmer" Beswick, Jess Tyree, and Arlen Vanke. "
So, I am still looking for one. Any help would be appreciated.
Hood Scoop
Bulldog: Good luck in your search. That scoop was also used on 54 up on the f800 dumps and school bus.
This year I spent countless hrs on FTE classified and E BAY. I did find something on ebay and lost bid at over $200.
I later found a good looking subs 69-70 Mustantang mach One tha ibought $150 with inturnal turn sig. This looks as if it will conform to contour of hood.I plann on a using this on a 53 hood.
I think I covered every scrap yard looking on the internet.Don't seem to be any BIG OLD FORDS left but I 'sure there are.
Sommwhere I have Ford Part # But just got out of hosp w/the second heart By Pass operation If you want it I'll try to find #
Not same but the heritage correct and I think will look good over t
he 5.o W/ mass air set up I have planned CAddy 53 Chuck
Hood Scoop
Thanks for the info! I thought they looked extremely close to Ford's. I had even mentioned this to darkman a while back when he was looking for one, but never did an actual search on the subject.
Keep your eyes peeled on e-bay using the key search words "Super duty hood scoop". They aren't on there every day, but at times I've seen several listed there at once.
Just an update
I have my hood scoops. Yes that is scoops. I spoke to several people, and several hot rod shops. I found an original Ford truck scoop, and one off of a Pontiac Super Duty.
Now, for the record, there is no difference between the two. The Super Duty and the factory Ford scoop are identical.
The other point of interest is that the bead rolls on the scoop match the bead rolls on the 57 and 58 hoods. Also the grill lines on the scoop match the bead rolls on the 57 and 58 hood.
Now, I have a question. How far from the back of the hood should the scoop be mounted. I was never able to find a scoop that was still on a Ford hood so I could not measure.
The side to side is easy, I just match up the bead rolls, but I need to know how far forward.
Thanks
Thanks
evilwayz7
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
09-14-2007 12:28 PM
53fun100
02-25-2005 11:44 PM
