MAP sensor.... Do the O.E.M. numbers have to match exactly,
on
1 Post
The MAP sensor and the BP sensor look alike, and have the same connection, but are not interchangeable, to my knowledge. From what I read in the service manuals, the MAP sensor sends out an ac signal like a 'tone' which varys according to manifold pressure. The BP sensor is a variable resistor which sends a voltage between 1.3 and 1.7 volts, depending on barometric pressure when the engine is started.
The MAP sensor is used on engines without mass air.
Hope this helps.
Winford
Hope this helps.
Winford
kingsnkviper
08-22-2013 08:31 AM
Brett W 55 Ford
10-23-2010 01:01 AM
SilverBullet131313
04-29-2006 07:43 PM
Mitch in NC
16
08-04-2004 12:00 PM
