MAP sensor.... Do the O.E.M. numbers have to match exactly,
Old 09-25-2001, 10:35 PM
Dildine's Avatar
Dildine
Dildine is offline
if I try to replace one with one from a salvage? Does it matter if they come from a 4, 6, or 8 cyl. engine? The numbers I have are only different by one letter and it doesn't run right with the salvage MAP in it. Thanks BJ
Old 09-26-2001, 08:30 AM
winfordr's Avatar
winfordr
winfordr is offline
The MAP sensor and the BP sensor look alike, and have the same connection, but are not interchangeable, to my knowledge. From what I read in the service manuals, the MAP sensor sends out an ac signal like a 'tone' which varys according to manifold pressure. The BP sensor is a variable resistor which sends a voltage between 1.3 and 1.7 volts, depending on barometric pressure when the engine is started.
The MAP sensor is used on engines without mass air.
Hope this helps.
Winford
Old 09-26-2001, 10:32 AM
amsnss's Avatar
amsnss
amsnss is offline
kingsnkviper
08-22-2013 08:31 AM
Brett W 55 Ford
10-23-2010 01:01 AM
cowmilker08
Indiana Chapter
10-09-2010 02:05 AM
SilverBullet131313
04-29-2006 07:43 PM
Mitch in NC
16
08-04-2004 12:00 PM
Quick Reply: MAP sensor.... Do the O.E.M. numbers have to match exactly,
