MLPS Replacement
MLPS Replacement
I have done some research regarding my transmission problem, and have narrowed it down to water intrusion on the MLP/TR sensor. Ford has addresses this thru TSB 95-2-12. Is the replacement of this as simple as buying a new sensor, replacing the old and torquing up the bolts? From what I have seen the MLP is the same as the Neutral Safety Switch which I can get at autozone for 35 bucks. Is this the correct part or should I go a different route? Thanks for the advice gentlemen.
96 EB 351 auto
96 EB 351 auto
MLPS Replacement
You can get it at parts houses, such as Napa, for about $35. Ford wants around $100. Ask for a neutral safety switch, but specify that it's for an E4OD transmission. The MLPS is pretty much just a really fancy neutral safety switch. Before you pay for the part, verify that it has the same connector as the MLPS, since electrical parts generally are not returnable.
Johnny Bellardine
15
09-13-2022 01:22 PM
mr1
06-09-2016 08:48 AM
bigolebluef150
11-20-2006 03:09 PM
