front end
front end
I have a 1993 F150 with 38superswampers. The problem is it just started to shimmy or shake in the front end at about 35mph and stops when your going slower or faster you can realy see it in the stering wheel. I think maybe that I have one tie rod going bad but they all seem tight and strong. Its just strange that I get this problem only at a certain speed.
HELP Bob
HELP Bob
front end
does it do it all the time? The reason I ask is, my truck shakes bad when I first take off and the tires are cold. Swampers flatspot really bad. Once the tires warm up on the road it goes away. If that isn't it, and the steering is tight, try having the tires pad balanced. Mine rides great with my 39.5's(after they warm up).Good luck.
front end
[updated:LAST EDITED ON 04-Dec-01 AT 04:16 AM (EST)]Thanks for your help. But its only at that one speed warm or cold.Buy the way nice truck. Did you have to cut your front fenders? I was going to put a picture of my truck on here but I can fiqure out how you did it. Do you do alot of four wheeling with your truck?
front end
I did have to cut the rear of the front fenders alittle. I had already trimmed the bumper as well as spaced it out 1 in. This made plenty of room. As for the wheeling, It spends most of it's life carrying me back and forth to work. But I have Tested its abilties a few times more than I probably should have. Thanks. I am going to include the instructions for the pic. I got them from Madman.
Step1: post a message in the testing forum and attach the specified photo,
assuming you know how to do that.
Step2: veiw the message with the photo in it, at the bottom of the photo is
a web address, highlight the address, than right click on the highlighted
part and select copy.
Step3: go to the user menu, and go to edit profile. Now in the box that says
signature, right click in the white part and press paste.
Now at the bottom of the page click update. After its updated your photo
will show up in the signature section
hutchie
16
09-28-2014 11:05 AM
F100steve
01-28-2008 11:39 PM
