How do I dump my CA emissions
Old Dec 4, 2001 | 05:47 PM
cpnhgnjnky's Avatar
cpnhgnjnky
I was just wonderin' what all I would need to get rid of to get it off. I don't and won't ever live in Cali, therefore I want my hp back. Thanks.
cpnhgnjnky
Old Dec 4, 2001 | 07:27 PM
bsprowl's Avatar
bsprowl
First what year is it.
Second, for the last several years the emissions stuff is so much a part of the engine that is really can't be removed.
Old Dec 4, 2001 | 08:43 PM
cpnhgnjnky's Avatar
cpnhgnjnky
Sorry I did forget its a 1995 F150 4x4 5.8L Eddie Bauer Supercab E4OD tansmission.
cpnhgnjnky
Old Dec 4, 2001 | 10:52 PM
Pastmaster's Avatar
Pastmaster
How many convertors does it have? You can remove/hollow out the pre-heater and catalytic convertor. Also you can remove the smog pump. Can't say whether you'd gain noticeable improvement in power, but I did in my 89
'93 F-150 loaded and modified!
Several other project vehicles
Old Dec 5, 2001 | 12:05 AM
ddestruel's Avatar
ddestruel
a 95 california edition
Pastmaster's right the smog pump and the converter can be removed, also so can all the other smog tubesplug em off or remove the whole system. you have an EEC IV which shouldn't register the changes if i remember right... also the vacume selenoids on the drivers side of your motor if you wish to eliminate the vacume operated smog valves in the system, cap the lines after the selenoids, this will allow them to open and send a signal to the computer that they are in use, yet after that the rest of the system is gone the computer is none the wiser. I removed everything except the EGR and have had no check engine codes nor a loss of efficiency. Good luck and beware if your state ever adds emissions testing youll have quite a headache ahead of you. BTW Motorsport has an idler that will replace your smog pump and let you keep the same length belt i think.
Dusty
Old Dec 5, 2001 | 12:13 AM
Pastmaster's Avatar
Pastmaster
ddstruel: That's what I did. I wanted to just remove the pump so incase the truck ever has to be emissions legal it can be. I just put bolts in place.
I've heard that blocking the EGR will help power too, any insite in that?
Old Dec 5, 2001 | 09:59 AM
ddestruel's Avatar
ddestruel
Pastmaster
I have spoken to a couple of people who have removed thier EGR, some power increase since they were no longer reburning EG's but they lost some of thier mileage, the leaner run provided by the Exaust gas does seem like it helped the truck especially since it doesnt open up all the time. But thats all i know about it.
Cya
Dusty
Old Dec 5, 2001 | 11:04 AM
rabidranger's Avatar
rabidranger
cpnhgnjnky
New Member Introductions
May 23, 2005 08:51 PM
cpnhgnjnky
Sep 14, 2002 05:52 PM
cpnhgnjnky
May 26, 2002 11:10 PM
cpnhgnjnky
17
Jan 9, 2002 10:20 AM
cpnhgnjnky
Apr 16, 2001 05:17 AM
