'67 F100 w/3.03: shift rod bushings @ trans? (not @ column)
Old 03-30-2017, 09:05 PM
xanthias's Avatar
xanthias
xanthias is offline
I'm all set on my shift selector lever bushings for my 3 on the tree. But my searches are coming up empty for these bushings where the shift rods attach to the transmission gear selector levers on the left side of the truck:
Outboard side
Inboard side
Can anyone point me in the right direction?
Old 03-31-2017, 07:31 AM
orich's Avatar
orich
orich is offline
May be BIll or Jeff can find you some once they chime in.
Orich
Old 03-31-2017, 08:23 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Not sure if this will work with the original shifter or not.
https://www.summitracing.com/parts/h...M0-hoC3fjw_wcB
Old 03-31-2017, 11:29 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
^^The hurst clips likely won't be thick enough. They rely on the spring loaded clip for tension. The factory rods are held by E clips(shown in pic). There is no hole for the hurst clip.
Old 03-31-2017, 12:24 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
They will be either this at www.dennis-carpenter.com:
MakeModelBody StyleNotesYearFordCarAllManual 1957-59 FordGalaxieAllManual 1960-66 FordFalconAllManual 1960-67 FordFairlaneAllManual 1962-67 MercuryCometAllManual 1960-66 FordTruckF100/350Manual 1957-72
Our Low Price:$4.95 set
Shifter Bushing Set
Column Shift
1957 - 64
C3TZ-7343-A
Selector Arm Bushing & Insulator Kit
  • 2 Plastic Bushings & 2 Rubber Insulators
  • Exact of Original
StatusIn Stock
or this:
Home
Gear Shift Selector Arm Bushing
Zoom
MakeModelBody StyleNotesYearFordTruckF100/350Manual 1965-72 FordBroncoU-SeriesManual 1966-77
Our Low Price:$9.95 ea.
1965 - 77
C5TZ-7343-A
2- Brass Bushings & 2 Rubber Insulators
  • For Manual Transmission
StatusIn Stock
Old 03-31-2017, 05:35 PM
xanthias's Avatar
xanthias
xanthias is offline
Thanks!
JEFFFAFA, I took apart (destroyed) one of the old ones to take some micrometer measurements. I think you're right - C5TZ-7343-A is probably it. Ironically, I already have a set from D.C. but their description suggests it's also for the column so that threw me off the trail.
Tomorrow, I'll try to fit one and will report back here with the results.
The first set you posted, with the plastic insert, is for the column.
Old 04-01-2017, 11:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
MakeModelBody StyleNotesYearFordCarAllManual 1957-59 FordGalaxieAllManual 1960-66 FordFalconAllManual 1960-67 FordFairlaneAllManual 1962-67 MercuryCometAllManual 1960-66 FordTruckF100/350Manual 1957-72.
Shifter Bushing Set
Column Shift
1957 - 64
C3TZ-7343-A = 1963/64 F100/250 2WD / 90+ available NOS
  • Exact of Original
StatusIn Stock
or this:
Home
Zoom
1965 - 72.
C5TZ-7343-A = 1965/72 F100/250 2WD / Obsolete ~ 75+ available NOS
There are no replaceable bushings on the transmission levers.
Old 04-01-2017, 01:05 PM
Classicdriver's Avatar
Classicdriver
Classicdriver is offline
I wondered about this also because mine desperately need replaced as well, and like the OP have only found the bushings for the column arms and not the transmission arm. But if you guys think either of those will work on the tranny, then I will buy them. Thanks for posting
Dan
Old 04-01-2017, 01:16 PM
NumberDummy
Dan
Neither of these steering column selector lever bushings will work on the trans levers, as there is no way to install them.
Old 04-03-2017, 10:28 AM
Classicdriver
Very well, I guess I will find a generic bushing that will fit in there. That sucks. Out of all the parts available for these trucks, those bushings aren't one of them
Old 04-03-2017, 08:37 PM
xanthias's Avatar
xanthias
xanthias is offline
As usual, sir, you are right. Though I wish this time you weren't. The width of the transmission lever means you have to destroy the new bushing to get it in. So, I've pulled the rod and trans lever to take with me to ACE Hardware tomorrow. I have no choice but to figure out something because my originals are shot. If I'm susuccesful in cobbling something, I'll post back here with pics.
Top is old original, worn and damaged from removal. Bottom is new, showing more narrow profile. Won't work.
Old 04-04-2017, 03:35 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
If that is the "only" difference I would cut a little of it away with a sharp razor blade to open up that width. CAREFULLY. Never cut towards any part of your body.
Old 04-04-2017, 04:54 PM
xanthias's Avatar
xanthias
xanthias is offline
Unfortunately, the outer diameter of the bushing is enough that, once you wedge it in, it's compressed. When you then insert the brass, it punches through the rubber and destroys it.
Here's what I came up with today.
Bronze bearing 3/8"OD (ACE Hardware item #58101), 1/2" OD, 3/8"ID Nylon bushing (#40907)
The nylon bushing is basically a press fit into the transmission shift lever. You may need to dress the lever a tad with some emery cloth.
The flange on the bronze bearing is large enough that it will not pass through.
This is what you have before you cut it down to proper width to allow the circlip to be inserted back onto the shift rod
This is with bronze cut down to length. Nylon is already perfect and you can use as a guide to cut the bronze. I used an old copper brake caliper washer on the end.
There isn't much you can do to keep it centered side to side but I'm thinking that should not be a huge problem.
Old 04-04-2017, 06:29 PM
xanthias's Avatar
xanthias
xanthias is offline
Installed:
Old 04-19-2018, 06:42 PM
ericknight's Avatar
ericknight
ericknight is offline
I had the same problem a few years ago and posted a question and my solution but I used Photobucket and the pics don't work now. https://www.ford-trucks.com/forums/1...-bushings.html The worn out bushings on the shifter arms are replacable. I had a local machine shop make me some out of solid brass, works great. Here are the pics.
Quick Reply: '67 F100 w/3.03: shift rod bushings @ trans? (not @ column)
