A nice smooth idle... Is it possible?
I was told by a long time mechanic that getting a carbureted straight 6 to idle smoothly was impossible. Is there some truth to this? My 83 runs well, really well, but the idle is a tad lumpy. I've done everything I could to tune this baby up. New Motorcraft plugs, wires, cap and rotor. New fuel filter and pump. New ignition module and coil. Rebuilt the carb and replaced the rusted out choke stove heat tube. Checked all vacuum hosing. Yet, the idle does not purr steady.
Your thoughts?
Your thoughts?
Your thoughts?
Your thoughts?
Was just posting the other day I have been trying to find the source of a rough idle on my 2.9 EFI 86 ranger for the past 6 years. I tried somewhat to straighten it out when I first got it with the standard stuff, and then through the years have changed various things out for various reasons, never have gotten rid of it. The other day I finally figured it out, the oxygen sensor is bogus. It doesn't throw a code but it isn't right either, it runs so much better with it unplugged. I am finding out these things probably should be changed out like quality sparkplugs should, probably every 50,000 or so.
Does your six have the computer system with the carb and the oxygen sensor? Does your distributor have a vacuum line going to it?
My I6 idles very smoothly. It's still feedback, with a rebuilt carb, new plugs, distributor cap, and wires. Runs like a champ for the most part. I plan on going Duraspark or HEI along with a bigger carb and intake in the summer though in hopes of improving the abysmal MPGs and power.
Please consider offering the feedback related components to someone on the forum who is trying to maintain their feedback system [don't just throw them away].
I never throw anything away haha! If I decide to sell them this is the first place they're going up.
And initial timing is set to what? If too advanced it can run a little rough, too low and it can be lopey. Idle mixture set for highest RPM/highest vacuum? For smoothest idle you may end up a hair richer than highest RPM/vacuum. Verify the mechanical advance is working smoothly and fully returning every time, that initial timing does not vary if you rev it and let it return to idle. Mechanical advance needs to be cleaned and lubricated periodically. Sometimes springs may be weak and not fully return.
