Performance 390 hose modification?
Old 03-12-2017, 03:46 AM
Keith Mitchell's Avatar
Keith Mitchell
Keith Mitchell is offline
Wondering, I was planning on getting rid of the heated carb spacer since I'm going to a 4 barrel holley and edelbrock RPM intake, .. I know colder air translates to more hp... Am I losing anything by bypassing the spacer and running directly to the water pump and intake tube? .. Also is there any vacuum lines routing diagrams for performance engines.... I'm changing valve covers and air cleaner that a lot of those lines ran to
Old 03-12-2017, 12:24 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The only thing that heated spacer is for is to prevent carb icing in the cold. Not knowing where you are, that might still be a concern, but an in-line valve for the heater core could do two things in the summer. Keep the carb cooler, AND shut off the heater core so it's not radiating heat into the cab.
As for vacuum lines, well, it's brake-booster, PCV and vacuum advance at it's simplest.
Old 03-13-2017, 06:50 PM
69cj's Avatar
69cj
69cj is online now
In my op. Just use a phenolic spacer to decrease temp. And increase velocity. 1/2 to 1" whichever will fill the bill.
Old 04-04-2017, 09:53 PM
1972-34ton's Avatar
1972-34ton
1972-34ton is offline
2X what 69ch said. I went a step further. My stack is, from the bottom: Thick gasket, plastic OEM spacer ~3/4", gasket, large heat shield homemade, gasket, heated spacer, thin gasket, and atop it all the carb. Since it gets really hot here in summer, I later added a ball-valve shutoff.
Old 04-05-2017, 07:49 AM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
Make sure you hook up the PCV. I live in Texas, so when I rerouted the water from going under the carb it almost stopped the vapor locking problem.
karljay
29
01-24-2017 08:29 AM
Craigs 65
08-03-2012 12:45 PM
71FoMoCo
10-06-2003 11:06 PM
broncr
04-13-2003 11:42 PM
78bigunns
01-20-2003 09:38 PM
Quick Reply: Performance 390 hose modification?
