Carb spacer replacement
Old Jan 20, 2003 | 09:10 PM
78bigunns's Avatar
78bigunns
Question Carb spacer replacement
My motor is a 74' Lincoln for starters. The carb spacer on the truck has two coolant ports. In the rear it has a sinlge port from where I run my PCV. The gaskets are all but impossible to find for this funny shaped spacer, therefore I have made my own manifold-spacer gasket. I want to put on a aftermarket 1" spacer and use the correct gaskets, but am concerned about blocking/rerouteing the heater hoses away from this old spacer. What purpose did they serve, do I need them? There is another line going to the heater core, and the spacer is plumbed between the line coming back to the water pump. Can I just get my new 1" , disconnect those hoses and be allright? Thanks, Blair
Old Jan 20, 2003 | 09:38 PM
Mil1ion's Avatar
Mil1ion
Yes, Just disconnect/dicard them and re-plumb for the heater core.
They were only for the Carb spacer for quicker heating up.
