Hey all, I'm trying to run a wire through the firewall. Is there a good place to do so that's already there?
I'd hatell to drill a hole in a near pristine truck.
It's an '01 F250 XLT
Thanks all
ive found that where there is already wires running thru from the factory, there is usually a lil rubber boot that I can sneek my wire thru also. sometimes just a tiny slit in the rubber and youre good to go. ive used the one at the steering column on this truck.
I have an automatic 06 and ran my wires through the rubber plug where the clutch linkage would be if the truck had been a stick shift. I had to pull back the firewall padding to get to the plug.
