I have one clue for my high rough idle
Old 03-23-2017, 08:37 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Ok, best of luck..
  #317
Old 03-23-2017, 08:53 PM
sandymane's Avatar
sandymane
sandymane is offline
I wish you knew how much I appreciate all you did for me and all the time and effort put forth. My most sincerest of thanks. I thank all that helped also. Sandy
  #318
Old 03-23-2017, 08:57 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Yeah, just makes us a little smarter each time... I'll make a note if I come up with any thing, can't get in the weeds on the internet to easily. You're not alone out there with a 95' 4.9L with a Rough Idle.
  #319
Old 03-24-2017, 03:01 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
When you get the chance, let me know what the wire colors were on your EVP connector.
When you had your vacuum gauge hooked up was it a steady 20psi ? Was there any fluctuation?
thanks..
  #320
Old 03-24-2017, 03:17 PM
sandymane's Avatar
sandymane
The middle wire appears to be grey. The two on the sides appear to be black and the other appears to be black with a color stripe. They are very faded and have been taped from the loom to the plug.
vac gauge showed a steady 20 PSI
I also removed the EGR block today with no ill effects.
  #321
Old 03-24-2017, 06:40 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Ok Thanks. I'm guessing the other two are Brown with stripe, but no need to check.
When you get another 100 miles on your plugs, you could pull them, and compare them to the charts on the web, to see if the condition of your plugs shed any light on things.
  #322
Old 03-24-2017, 07:13 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
When you did your compression test, did you do them one at a time, or did you take all the spark plugs out at one time, then test?
  #323
Old 03-24-2017, 07:36 PM
sandymane's Avatar
sandymane
All were out when I tested.
enzer2406
02-18-2011 01:39 PM
IcemanV8
22
04-11-2008 06:34 PM
kjg26
02-05-2006 01:05 PM
spider42
01-24-2003 12:54 PM
paleryder
1978 - 1996 Big Bronco
09-30-2002 12:11 PM
Quick Reply: I have one clue for my high rough idle
