65/66 tailgate opening dimensions
Hey guys,
First thread start on here so be gentle!!
out here in Scotland patching up an old 65 styleside longbed that's been hit hard on passenger rear at some point in the past, causing the right hand upright that contains the rear lamp assy to lean out in the head.
Ive got a tailgate getting shipped from Texas as we speak, but need to square this up and get it into paint shortly.
Could someone please measure the top and bottom widths, as well as a length across the diagonal of their tailgate opening!?
thanks
Rabb
thanks
Rabb
C4TZ-9940700-A .. Styleside tailgate: 1964/66 F100/250 2WD; 1966 F100 4WD.
September 1966: Ford obsoleted the C4TZ tailgate, replaced it with the 1967 (1967/72) F100/350 C7TZ-9940700-A tailgate for use as a "service part replacement."
ALL the mounting hardware is exactly the same, but the 1967/72 tailgate looks slightly different. Has smaller FORD letters surrounded by a raised ovate scallop line.
Both these tailgates are 66 7/8" long x 21 1/4" high.
IF your '65 has 4WD or is an F350, the tailgate is different.
I agree. However, I measured 67 1/4" top and bottom (67 5/8" diag) which would seem more in line with the dims ND gave for the tailgate though.
Put a large carpenter square on the bed and butt it up against each bed side. I would assume that over the years, the top of each bed side, has bowed outward.
In the past, (I've done this on a couple trucks), spot welded a plat with a hook on it, to the top of each side of the bed opening, and another plat with a hook, at the corner junction of the bed floor and the bed side. Connect a 'come along' and crank it down,pulling the top of the bed inward till it is square. Use the carpenter square to check when it is true. The spot welds on the plates can be cut later and plates removed.
uncle champ
04-11-2019 06:13 PM
frty7ford
02-18-2018 11:00 PM
HillBillyBuddha
04-17-2013 10:12 PM
santi2322
05-04-2010 01:43 PM
