Gas blowback when filliing
Old 02-24-2017, 09:30 AM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
So, stopped for gas for my '73 F100 and I could hardly get the gas cap off.. Nothing appears wrong with it.
Then, gas would not go into the tank without it blowing back out of the filler tube.
I took off the vent hose and blew air into the tank and out of the hose. No obstruction.
I finally got the tank full with on and off with the gas pump.
Earlier this year I noticed a little of this issue developing but this time it was a real difficult fill.
Old 02-24-2017, 10:33 AM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
A few questions:
Was truck running when you were filling up? (I know the right answer LOL)
Gas cap hard to get off due to? Over pressure or vacuum?
Look at your filler hose and vent hose and make sure its not crimped going over the frame rail.
Old 02-24-2017, 11:32 AM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
Truck wasn't running. The vent hose was pretty stout and round. I had to cut it to get it off. Gas tank has never been off.
Why is it always the tank is full when it has to be removed? LOL
Old 02-24-2017, 12:07 PM
F250_Super_4X4
The only way it could be spitting back at you is an obstruction in the fill hose or somehow gas is getting redirected into the vent hose. 77 and lower require a 2 way vented cap which isn't made anymore so drill a 1/8' hole in the cap or at the top of the vent tube. I have seen some gas tanks with so much vacuum that it has collapsed the rubber portion of the fill tub.
Old 02-24-2017, 03:09 PM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
If the filler hose is flattened where it goes over the frame, replacement filler neck hose is available at NAPA, but it is not cheap. They sell it in 3-foot sections at 20 -25 bucks a foot. You can get it from rockauto ,but you have to pay shipping. I think the piece I bought is 2 1/4" Measure the neck of the tank to be sure. As far as the gas cap, old style pressure/vacuum vented caps are still available. Autozone lists one, part# 6040. It fits mid 60's Ford cars. You will have to try it to see if it will fit your filler neck. I've got a similar one on my 78,but im not sure what it came off of. You do not have to remove the tank to change the filler hose.
Old 02-26-2017, 09:06 AM
PapaBearYuma's Avatar
PapaBearYuma
PapaBearYuma is offline
Bronco Graveyard carries the filler hose. It's made by Dennnis Carpenter and has the u-shaped piece of metal to flatten and protect the hose where it goes over the frame rail.
Bronco Graveyard also has gas caps for the various years.
I put a new hose and caps on my 78, and immediately started having pressure problems because the caps didn't vent. Left me stranded once, and may have contributed to the failure of my electric fuel pump. I drilled 1/8" holes in the caps and haven't had any problems since.
Your problem is likely not the caps, but possibly a collapsed filler hose
Old 02-28-2017, 04:30 PM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
You do have to drop the tank to replace the filler hose. The hose snakes over the frame. What a poor design.
Old 02-28-2017, 04:40 PM
SeaCarr's Avatar
SeaCarr
SeaCarr is offline
Thanks for all the suggestions. You do have to drop the tank to replace the filler hose. The hose snakes over the frame. What a poor design. The filler hose was nothing special to the eye. It was 44 yrs old and mushey. Looked pretty flat. Anyhow, full tank, siphoned the gas, dropped the tank, cleaned the corrosion, primed, painted, replaced all of the hoses, cleaned the fuel gage ground, drilled 1/8" hole in the vent, refilled and tested. Not bad for two 70+ Ford fans.
One bonus I did not expect. I have had a slight engine stumble at start from stop. This is completely gone. Totally. Only thing I can point to is the gas tank pressurization or lack there of. Pretty strange but good.
Old 02-28-2017, 06:06 PM
PapaBearYuma
good job getting that tank out and serviced! and congratulations on getting that stumble fixed at the same time
Old 03-01-2017, 07:49 AM
F250_Super_4X4
Good deal!!!!
Jeff Olsen
07-15-2010 02:24 PM
bigfoot22
05-23-2009 07:37 PM
BrentusBrutus
1978 - 1996 Big Bronco
08-23-2004 09:20 PM
Petiboy
07-14-2004 06:12 PM
mpmccarthy
06-17-2004 10:35 PM
Quick Reply: Gas blowback when filliing
