CHEAP PAINT JOB
#31
I would not spray clear over the paint if a hardener was not used, there is a chance it will lift.
The cheap paint I am thinking with the hardener will hold its gloss better without clear, but my experience with cheap enamel and no hardener isn't good, the paint never fully cured and could not be sanded. Had to be removed with paint stripper and razor blades when it came time to repaint.
A buddy of mine paints every car he builds with hardened rustoleum and mid grade automotive clear, they look great.
I paint my frames and did the inside of my cab on truck #2 with Tractor supply Valspar and hardener, then did the dash with automotive clear and metal flakes. Worked great and no paint lifting. I got the paint on clearance when TS was switching from Valspar to Magic, was around $15 a gallon.
#32
#33
#35
Bob, I used some of that Magic brand tractor paint from Tractor Supply recently to paint a Massey Ferguson tractor. It sure faded out fast. Heck, within six months the red was getting real dull. The grey seems to be holding up pretty well. I know that reds are a pain in the rear but still, I figured I'd get more than 6 months. I guess I better rub it out and find some protection for it.
I want to paint my truck the original Meadow Green. I might try Hillbilly Bob's technique and use some of the Oliver Green tractor paint and start adding black into it until I get close.....hmmmmm
Bobby
Bobby
50tbrd88
60
06-15-2018 08:53 PM
Jim-A
97
08-30-2013 04:10 PM
mfnmxr
02-15-2012 11:12 AM
