I don't want to ask, but have to
I need to know what vehicle (year, engine, F150 or 250, etc) to get the high pressure line from for a Saginaw P/S pump conversion. I have a 96 F150 with a straight 6. I got the Saginaw pump from the correct e-series van that also had the straight 6. I have seen threads where the poster "thinks" or is "pretty sure" that the hose I need is from a 1977 F250, but they don't say which engine that truck has - I assume another straight 6 - but don't know for sure.
The reason I don't want to ask the question is because I know that somewhere on the site, the answer is already there. But after spending 3 hours searching and using advanced search, my eyes and mind are starting to bug out. There are so many threads about this conversion, but I just can't seem to find the answer to my specific circumstance. I found threads that state the correct hose for different engines, or different models, but nothing for my specific circumstance. I apologize for another thread about this.
The 70s' F series model sag conversion is different from the 90s' E series conversion.
Just source the high pressure line from the particular E series van you got the pump from.
If I still have the original hose off an E series pump we snagged sometime back, I'll take a pic of the "steering box" end.
It (I know, ) SHOULD be the same (swivel, o-ring type) across the years/engines.
If someone has better, more positive info, I'll gladly deffer to that.
The 70's F series uses inverted flare fittings on both ends...........Not sure about any of the rest of them.....I just went thru the whole "finding the right hose" thing to hook up a Dodge Cummins pump to my stock '78 steering gear, Dodge used the "O" ring type fittings so it wans't looking good besides having someone crimp me up a custom hose. I ended up making my own fittings by brazing #6 Male JIC fittings to both the Ford and Dodge tubes then having a #6 hose with #6 JIC female fittings built.......The up side to the way I did it is if I ever blow a hose in Podunk Wyoming.....I can always find someone to build a #6 JIC hose, or If I blow one of my "adapter tube" fittings, I can buy the corresponding hose assembly and have someone cut it up and braze on another #6 male JIC......any one with a hacksaw and an oxy acetylene torch can do that for me.........The custom crimped hose assembly route could leave me setting for weeks, trying to round up all the correct pieces/parts and trying to find some place to put it all together......Just my 2 cents worth......which may be worth considering if you can't find something off the shelf that works.....
Saginaw P/S pump with 300: 1975/96 Econoline.
The shaft on the Corporate II PS pump is not the same diameter as the E series Saginaw.
Also the bracket is specific to the E series pump face.
The bracket on your truck will not have this face:
The Saginaw that I converted mine to before Cardone ran out of them was ordered by their part #. It uses a smaller Ford specific pump shaft and a C shaped adapter that allows it to be bolted to & line up with Corporate II brackets & front dress.
NPD still offers a Saginaw for 78-79 100s'-350s' for what its worth.
Nothing is implied about its originality to a specific vehicle.
I just used the hoses (they were in surprisingly good shape) from the '96 E-Series 4.9 van where I got the pump and bracket from, it was exactly plug and play. I removed the old, leaky, whiney CII pump & bracket, and lines and installed the E-Series bracket, pump, and lines. Did a flush, of course. You'll love it. Might just be the best mod I've ever done on a vehicle...no joke.
Don't have the paper catalog to refer to right now, but looking online yields this:
(First item on page)
https://www.npdlink.com/store/catalo...p-50331-4.html
No tank & high core charge.
ndBrody
10-01-2018 08:48 PM
ubermich
04-23-2018 11:51 AM
compressorguy
03-18-2011 02:37 PM
