300 I6 in 1950 F6
The T98 will have the old square pattern, and the 300 will have the rectangular "butterfly" pattern.
You could inspect the bell for the six and see if the transmission bearing retainer will fit into the hole in the bell. See if the top two or even one bolt hole matches up. Check the input shaft length.
Then it get's tricky. You may be able to drill holes to match the trans pattern. The question then would be is there enough material to thread into. Or could you put a bolt through from the back side and use it as a stud to hang the transmission.
Since the square pattern died as the 240/300 was born, I don't think you'll find a bell for the 240/300 with the old pattern.
An adapter would have to be fabricated and might interfere with the proper input shaft depth.
My T98 has 6 studs.
Interesting. I was going off info here:
https://www.novak-adapt.com/knowledg...ns/manual/t98/
6 bolts.....well, they wanted to make sure it wasn't going anywhere I reckon.
I found a bell with that pattern in of all places a Ditch Witch salvage site:
http://www.hceweb.com/used-trencher-...-machines.html
Does your current bell look like this?
http://www.ebay.com/itm/1930-1931-Mo...-/222420645238
Maybe more like:
http://www.ebay.com/itm/48-49-50-51-...-/142290017825
or
http://www.ebay.com/itm/1932-1952-Fo...-/322433960775
Maybe more like:
or
390Highboy
02-03-2007 05:38 PM
