300 + T-98
Old Apr 9, 2006 | 08:42 PM
HT32BSX115's Avatar
HT32BSX115
300 + T-98
Howdy all,
Does anyone know if a 300 will bolt up to a T-98 and/or if there's a bell housing that bolts to a 300 and a T-98?
My T-98 has a Y-block connected to it right now and I'd like to replace it with a 300.
Thanks!
RIck
Old Apr 9, 2006 | 11:44 PM
optikal illushun's Avatar
optikal illushun
the bellhousing will not fit. u will need a small block ford pattern to make it work at the least.
Old Apr 10, 2006 | 12:05 AM
HT32BSX115's Avatar
HT32BSX115
Is it possible that the truck version of the 300 had a different bell housing pattern?
https://www.ford-trucks.com/forums/s...07#post3585807
Old Apr 10, 2006 | 12:44 AM
Col Flashman's Avatar
Col Flashman
The 300c.i.er was & is only a Truck & Industrial application engine, the 240c.i.er was used in cars.
The Bolt pattern of the 289/300/302/351 are All the same, if a Trans bolts up to 1 of these, it will fit them al.l
Old Apr 11, 2006 | 01:22 PM
sierraben's Avatar
sierraben
The bolt pattern is all the same for the engines mentioned by Col Flashman, as well as the 300-6.
HT32BSX115, the T-98 should bolt right up to the 300 with the correct bell housing.
T98 is basically the same as a T18.
Just make sure that the bell housing trans opening matches the transmission front bearing retainer diameter.
I think it's either 4.848" or 5.125", depending on the year of the trans; but don't quote me on that figure.
Old Apr 12, 2006 | 12:51 AM
HT32BSX115's Avatar
HT32BSX115
Ok....Well then I would need a bell housing that will either bolt to a T-98 (mine) OR.....find a transmission suitable for a 16,000gvw truck that will bolt to a 300.
I do know that the 300 was used in certain 60-70's F-600's so I know it can be done.
It does have to be a trans that has the E-brake on the back of the trans to work. I have dual cyl brakes on the back of my truck.
The problem is mostly that most wrecking yards don't hang on to medium duty trucks. they are a little hard to find unless you can find someone that specializes in them....
I know they're out there.....I'll just keep looking...
Old Apr 12, 2006 | 12:27 PM
HT32BSX115's Avatar
HT32BSX115
Well
I have been doing a little searching around and I have found that the f-600 as late as 1973 came OEM with the 300 and a 4 or 5 speed trans. I'm guessing the 4 was a T-19 (just like my 86 F-250 had in it?)
Does anyone know the model number of the 5 speed that might have been available in the F-600 and would it have been an OD trans?
There doesn't seem to be a lot of wrecking yards around here in the NW that have medium duty trucks. Evidently the F-600's came with a somewhat heavier duty engine than a 1/2 ton truck.
I'll assume that any transmission that came in an F-600 also had the E-Brake on the trans too.
Old Apr 13, 2006 | 12:39 AM
sierraben's Avatar
sierraben
Try either Hemmings Motor News or Truck Trader magazine.
For some reason I thought you had one of them pickup trucks, not big foot.
