F-150 94 column shifter broke.
The video shows the bottom then the top of the shifter linkage in the column.
I am moving the shifter back and forth through the video.
It is stuck in Park.
Ideas???
BTW, I looked for the loose-bolt issue at the end of the shifter shaft. No loose bolts.
https://m.youtube.com/watch?v=tY3KcUJF0-c
Ideas???
Received 3,117 Likes
on
on
on
I got my shift tube assembly from oreillys for $30. It was in stock.
This video was very helpful. Somethings are going to be different, but it shows the important stuff.
If you have the tools handy and some time. It is not too hard. The video really walks you through it.
If I recall correctly you will need:
7mm, 8mm, & 13mm sockets. A Torx-30 (star point) bit or socket. A small flat blade screw driver. And daylight. Did mine after dark. Would not recommend doing the same.
I used my smallish 20V impact to loosen everything, but I used a slim-line right-angle adapter and a T-30 bit. Then reinstalled the screws with my drill. The impact driver would have stripped the aluminum holes.
Let me know if you have any questions the video does not answer.
I'd still like to know how the shaft bent and the housing broke. The bushings were fine. All the screws were tight. Then again it is 22 years old and has 205K miles on it.
Dorman OE Solutions - Automatic Transmission Shift Tube
Line: DOR | Part # 905-100
$28.99
$28.99
on
Just be sure to lube your shifter cable at both ends.
I suspect that is why mine broke in the 1st place.
I popped the cable end off at the column. Lubed it at both ends. Then worked the cable in and out P-D1. With the truck off of course.
Glad to help. And thank you to those who've helped me.
That's what makes this site great. Ford guys (& gals) helping each other keep their Fords out of the junkyard and on the road.
