IPR value and intermittent rough idle.
As you may or may not know it's a real treat on these early builds to get at the ICP.
You will need the correct socket to get it out if that is the culprit, and check the pigtail good as well, for oil soaked condition. If so, replace it or you will still have issues.
As for your MPG, you stated 30 to 40 mins of idle time, that is gonna drag the MPG down big time. Do you have the high idle mod? These trucks don't like so much idle time and that mod might save some headaches.
I've been reading several threads regarding ICP replacement. Sounds like a challenge but I'll be ok. I was a tech for 15 years.
What the hell is with the price of the ICP? It's basically an oil pressure switch. Any particular place to get the best deal and anyone have the part number for an 03
I figured my idle time was a factor. I get to work around 5:15am and when it's cold I let it run about 20 minutes until I go in the plant. I've been trying to let it only idle 10 minutes. My truck has high idle. It actually does it on its own and rather quickly after start up. Even if I had a switch I would wait the same time begin running the rpm up just to ensure good oil flow.
So it's funny with these things. You need to build some heat in the 6.0 before driving but that idling hurts mpg. I usually wait to drive until ect is at least 100 degrees. I must admit, I need to stop driving the X around town on short trips too. I've been waiting for some parts for my wife's vw so she's been driving my explorer. Once the vw is fixed I'll be driving the explorer on short trips and the X just to work 4 days a week.
With that said, only OEM here will work. You can try a woo-flung-dung special as others here have, only to replace them a month later after they start wigging out and fail.
I get my OEM stuff from Autonation, formerly Tousley Ford
ICP sensor, 03-early 04, rear mounted (I.C.P.) : AutoNation Ford White Bear Lake | Parts & Accessories
Ed at FICMrepair.com is likely priced the same.
You might be a good candiate for a 200* Mishi t-stat, the 6.0 is happier and more efficient up around 200*, many of us have seen a gain of 1 mpg or more.
Can always try cetane boost as well.
DTR has a good vid for the early builds.
Www.ficmrepair.com ftw!
Ed
Well I'm pretty certain my oil leak is just the drivers side valve cover. It doesn't appear there is any oil leaking from the top of the motor down. Definitely see oil around the outer edge off the valve cover, from front to back. Although there is more residue around the 90 degree plumbing elbow someone put in the valve cover for the crankcase breather that is now dumped under the truck. Is it common practice to install a plumbing elbow and is the valve cover threaded to accept such a thing? I guess it's quite possible that the oil is coming from there. Kinda hard to tell for certain.
There are a few that do them but not real common. No, the valve cover is not threaded, so possible it just needs a new o-ring
I don't know what originally would have been in the vc in this hole. Was the original piece just pushed in with a grommet? I'm just trying to be clear before I go and just start tugging on this pipe. I think it would be a good idea to replace the o ring. At least eliminate that leak.
I'll have to look in my records i received with the truck but i remember it had 1 new injector installed when the truck had less than 50k miles and i would bet it was on the drivers side. Safe bet that's why it's leaking.
Should i reseal it with the ford silicone on the old gasket or replace the gasket?
Still didn't know much about the occasional rough idle.
Ok. I think I'll replace the gasket since I'll be that far anyway.
I would like to be more sure about the health of the ICP and if there are any leaks up there but it's so hard to see anything up there. Oh well. I'll wait until the idle issue gets worse or I see lower hpop pressures, which you said seemed normal. Thanks for your help. I respect your opinion about these matters and really appreciate the help.
#28
natewood75
01-17-2010 08:44 PM
modracr62
11-21-2007 09:56 AM
Boltgunner
11-24-2005 04:14 AM
