Vehicle 3 of 3
Vehicle 3 of 3
Year: 1990
Make: Ford
Model: F-150
Price: $3000
Mileage: 100000
Color: Blue with white stripe
Private or Dealer Listing: Private Listing
Location (State): SD
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Color: Blue
Engine: 5.8L V8 (351 Windsor) EFI
1990 F150 Extended cab short bed (6.75 feet) dual tanks. New battery, starter solenloid, relays, air filter, spark plugs and wires, battery wires, started, water pump, thermostat, temperature sending unit, radiator, new e4od tranny. All done within the last 10,000 miles. Could use new power steering pump (bypassed), windshield is a little cracked, tint is peeling away.
Has new aftermarket stereo, aftermarket speakers which I will most likely keep but may replace, ready to go for the cb and dual antennaes (swapped to the 80), ready to go and may include a 10" 500w sub and amp. New sub AND box, amp slightly used.
$3000 as is and will include belt tensioner and timing gear set.
$1500 without motor AND tranny.
I can rebuild any of these motors.
OverHeight
06-10-2011 08:37 PM
Xabrophazon
01-05-2006 09:01 PM
xxxcre10xxx
08-19-2003 06:21 PM
