did discount tire put the wrong size tire on my truck?
45 series are very low sidewall profile.
That is not stock.
If you only had 2 put on, running 4wd isn't going to like that.
If the outside diameter is not the same as the 75 stock size the speedo will not be correct within a reasonable tolerance.
All you have to do is look at the new tires to see if the side walls are very short.
Your sure have a lot of bad luck!
Good luck.
That is not stock.
Good luck.
