carburetor questions/ Number Dummy or???
I am asking in this forum for a friend. Problem is on a big truck 1956 or so.
Has a big Y block and 4 speed, kind of an F-6 or 7. The carburetor on this engine is an odd ball 2 barrel that parts are basically hard to find. The engine it self is like a 292/312 but the manifold where the carburetor bolts up is much different in size than the standard old 2 barrels.
I want to put a later 2 barrel on it just to get it running but the bases are different. I was told that the odd ball base was similar to some other carburetors out there like Rochester or ???
Anyone know what would be a good cross over for this thing?
thanks.
thanks.
Look into the small based Rochester 2GC that a lot of chevys, like 283s, used. They are really simple to work on and prior to 1968 the pickup versions have manual choke. I probably have a couple around because I hoard the small base, side inlet 2Gc carbs to sell as cores to the guys who want to use them for 3 deuces.
Ford did use that same base on the last year of flathead Merc IIRC and it was an oddball looking carb. Maybe they used it on early Y blocks too.
odd carb....
jax1-2
06-25-2004 03:23 PM
dcdave
01-19-2004 06:40 PM
