1978 - 1996 Big Bronco
Quarter Panel Replacement
Old 02-10-2017, 05:19 PM
NewEnglander's Avatar
NewEnglander
NewEnglander is offline
Hey All,
I've had the Bronco kind of put away for a while, I've been doing rear quarter panel replacement when I've had the time. I have the new panel tack welded up but I'm not sure if I should fill every single gap with a bead? It just seems like it's to time consuming and I suck at welding.
I was thinking now that its welded up I could grind it all down and then do fiberglass filler. Any opinions?
Doing the first rough cut.
Lining it all up
Welded in place
Old 02-10-2017, 06:09 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
You should post this in the bodywork section, you might get a few professionals to respond. I would have it welded all the way. But if you are not confident in your welding abilities, I'd pay someone else to do it, that way you won't warp anything.
Are you going to replace the inner wheel house? If you do, I would drill some extra drain holes, and panel bond that piece in, since that is where they rust out.
Old 02-12-2017, 01:23 PM
NewEnglander
Thanks I'll post this there as well. I only cut out a the edge which was rotted. I honestly don't want to spend the money on replacements so I was going to come up with something else seal the inside of the fender well out.
NewEnglander
Paint & Bodywork
02-19-2017 07:18 PM
zombiefied 247
05-19-2013 02:12 PM
v8xploder
Paint & Bodywork
04-01-2011 10:18 PM
tommyleea
Paint & Bodywork
03-28-2007 09:37 PM
SproutW
05-06-2004 06:08 AM
Quick Reply: Quarter Panel Replacement
