335 to FE swap
Old 02-08-2017, 11:23 PM
Mat Molt's Avatar
Mat Molt
Mat Molt is offline
335 to FE swap
Have a tired 400 in a 79 f350 4x4 and the parts to put together a strong 428 im crious about motor mounts. Has anybody done this swap?
Old 02-09-2017, 12:18 AM
wyrm73's Avatar
wyrm73
wyrm73 is offline
All FEs use the same block and motor mounts, including the 360 which was the used in 4x4s from 73-76. Just get a set of those mounts and you should be golden.
Old 02-09-2017, 08:53 AM
DB429SCJ's Avatar
DB429SCJ
DB429SCJ is offline
Mounts are not a problem,but the bellhousing patterns are different.
Old 02-09-2017, 12:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1958/64 FE's use a different bolt pattern on the block for the rubber insulators than 1965/76 FE's.
1965 F100/250 352 4WD; 1965/66 F350 352; 1966 F250 352 4WD use the same engine mounting arrangement as 1961/64 F100/700 292.
Old 02-09-2017, 12:34 PM
somethingclever's Avatar
somethingclever
somethingclever is offline
I used the factory passenger car (galaxie) engine isolators and torched a new hole in the existing frame perch to locate the engine. It was about 1" rearward from the 335 series slot.
Cost - free.
4Speeds4Ever
20
01-17-2011 05:22 PM
BlueOvalBud
05-08-2010 07:12 AM
iggybob44
06-13-2009 10:12 AM
jav409
03-08-2008 01:46 AM
olfordsnstone
12-15-2004 11:17 AM
Quick Reply: 335 to FE swap
