Can't get engine to start with key, please help
Hi everyone, I have a 1973 Ford f100 that i swapped a 302 that i rebuilt myself and a Borge Warner t18 4 speed transmission out of a 74 f100 into. new starter, distributor, coil, plugs, plug wires its all new. it has a point ignition system which is stock to the truck but not the engine, i just bought a new distributor that was a point. but for whatever reason when I turn the key nothing happens, no noise of the engine or solenoid nothing, but the dash lights and everything turned on. i know its not the starter because when i jump the solenoid the engine turns over great with no problems or odd noises. i replaced the solenoid and now the battery trying to find the problem but no luck. i didn't do any work to the wiring harness at all just unhooked it for the swap but its all in exactly how it was before and the key worked fine on the old engine, which was a 240 six with a c4 auto. it may have something to do with the new engine not sure. please help me or let me know if you've had similar problems please.
Ryan
Ryan
It will take some step by step trouble shooting to find the problem. Good news is the battery, starter and solenoid seem to be in good shape since it will crank when you jump the solenoid. The wiring between the switch and solenoid is the problem... or maybe the switch itself.
As a first step, suggest you determine if the key is powering up the ignition coil correctly. Turn the key to run position and put a test light or voltmeter between the coil positive terminal and ground. You should see voltage there... maybe not a full 12 volts but at least 8 or 10.
thank you all for the quick replys I'll definatily start to try some of those things. i don't think it has much to do with the tranny because when I took the old one out there was no wiring too it but I'll still look into it. also thought that the truck may just be grounded bad all together so ill start looking. thanks again
Now keeping in mind that you swapped to a manual transmission, if you did not swap the steering column, make sure the automatic gear selector is in Park (or neutral) in order to start the truck. IF you did swap to a manual column, then the wires in the original NSS harness plug need to be jumped.
lineman12345678
13
03-06-2014 06:33 PM
piratenation43
05-09-2013 02:17 PM
ford collector
08-14-2012 09:49 PM
