1978 - 1996 Big Bronco
Bronco freezes if left out overnight.
Old 02-06-2017, 07:26 PM
Andy Mills's Avatar
Andy Mills
Andy Mills is offline
i have a 96 bronco 5.0 Eddie Bauer. My truck will not start. Battery is fine. Had it taken to the shop, had it back for almost 2 weeks now. She doesn't start again. She starts to fire, but doesn't turn all the way over. I need some help. I have no idea what's wrong
Old 02-07-2017, 09:58 AM
jimbo285's Avatar
jimbo285
jimbo285 is offline
Check all the connections at the battery and starter. Check the grounds too. Also, was it ok when it left the shop? Maybe the alternator isn't recharging the battery and it took this long to drain the battery? Check those connections too.
Old 02-07-2017, 11:23 AM
andym's Avatar
andym
andym is offline
What does "battery is fine" mean? Did you have it load tested?
What does "starts to fire but doesn't turn all the way over" mean? Either it turns over or it doesn't.
What did the shop do to it to fix the problem for 2 weeks?
How many miles? Repair history? Has it done anything like this before?
Need LOTS more info to be more helpful.
Old 02-07-2017, 12:54 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Pull the battery, and let it sit overnight, then have it tested.
Bowtie_Schmowtie
03-19-2018 06:05 PM
unclebuck
Bronco II
08-21-2006 08:56 PM
rshissler
05-21-2006 09:31 PM
blueriverfaery
01-17-2005 05:51 PM
Whitty
12-15-2003 10:19 AM
Quick Reply: Bronco freezes if left out overnight.
