Cruise control?
s is mainly vacuum. Without it, it will not operate. You should see the mechanism on the drivers side near the firewall. Check the lines there first. Then, there should be a vacuum dump attached to the break pedal. Check that this line is not leaking at all. If both are good, then it is time to check for power. Under the dash to the right of your leg, you will see the computer for it. Two screws hold it in place. Check connections and clean them. After that, I am at a loss. Possible problem with on/off button in steering wheel, etc.
The EVTM has a good troubleshooting guide. This is for an '86, but your '85 should be very similar:
Speed Control - ???Gary's Garagemahal
dyoungen
01-19-2012 09:39 AM
fifeo
10-12-2010 03:51 PM
ECONOLINITIS
12-21-2004 11:08 AM
