cruise control problem
Old Oct 10, 2004 | 10:34 AM
woodranger's Avatar
woodranger
Hi, I recently noticed that my cruise control and horn don't work anymore. This leads me to beleive it's an electrical problem , not a vacuum leak. Any ideas on where to look?
Old Oct 10, 2004 | 10:38 AM
Dave257's Avatar
Dave257
Sounds like the slip ring on the steering colume. The horn, Airbag, and cruise control send there signals thru it.
Dave
Old Oct 10, 2004 | 12:36 PM
maticuno's Avatar
maticuno
What year is the truck? I'm not sure what year they switched, by my 98 doesn't use a vacuum operated cruise control anymore. It's servo powered.
Old Oct 11, 2004 | 07:04 AM
woodranger's Avatar
woodranger
thanks for the reply, It's an 87 with a 92 engine, I tihnk from searching the archives it's probably a fuse.
Old Oct 11, 2004 | 07:08 AM
woodranger's Avatar
woodranger
Dave forgive my ignorance but what is the slip ring and does a 1987 ranger have one?
Old Oct 11, 2004 | 08:40 AM
Dave257's Avatar
Dave257
A slip ring is the contact under the steering wheel. Switches mounted on the wheel need to have a sliding contack so the wheel can be turned and not pull the switch wires loose. A 87 is a little older then I'm use to dealing with, but I would thiink it has one.
Dave
