Door Striker Bushings
Old 02-01-2017, 05:29 PM
Binkowski's Avatar
Binkowski
Binkowski is offline
Brass would be too soft and not as pliable as the bushing.
Old 02-01-2017, 06:38 PM
Fordication's Avatar
Fordication
Fordication is offline
You do not need the whole striker, all you need is the plastic bushing I mentioned and you get a set for $3.
Old 02-01-2017, 06:39 PM
Fordication
Originally Posted by Fastback460
Have you used just the striker bushing from NPD? I need a new one for my drivers side door, but I don't want the entire striker bolt.
I want to get a bushing that is going to last awhile.
That is all you need and as I said you can get a set for $3 on ebay and be done with it.
Old 02-01-2017, 07:13 PM
seagiant's Avatar
seagiant
seagiant is offline
Originally Posted by 1993_f350_2013
Could a guy just chuck up a piece of brass in a lathe and turn the OD and ID and wala? Or would the brass be too hard?
Hi,
I thought of that?
But the ones I found on ebay are cheap enough!
If they don't last I will make some out of nylon.
This is easy to get at a used Indusrial Wharehouse!
Old 02-01-2017, 07:38 PM
moose4x4's Avatar
moose4x4
moose4x4 is offline
Originally Posted by seagiant
Hi,
I thought of that?
Check at Oreillys or another parts store. I was using air brake nylon tube and cutting it to length. This is before you could buy them anywhere. Can't remember if the size is 1/2 or 5/8 ID.
Old 02-01-2017, 07:56 PM
sandymane's Avatar
sandymane
sandymane is offline
I cut a fuel line the length of the bushing area and then cut it length way and just pushed it over the pin. The fuel line ID is slightly smaller than the pin but it's no problem. The doors shuts perfect with little effort and no rattle at all. So far they are holding up much better than the nylon.
Old 09-21-2017, 06:21 PM
Davie J.'s Avatar
Davie J.
Davie J. is offline
How do you get the bolt out of the striker assembly? I bought the bushings and removed the torx bolt, but the bolt will not come out of the U-shaped assembly. I can't figure out how I can replace the bushings.
Old 09-21-2017, 07:14 PM
Binkowski's Avatar
Binkowski
The bolt will come out. Just keep tension on it while you adjust to keep turning it out. Hopefully you marked the position with painters tape before you started. That helps making the re-install easier.
Old 09-25-2017, 08:19 PM
Workingstiff's Avatar
Workingstiff
Workingstiff is offline
I fixed mine with a steel 1/2"id x5/8"od bushing from local hardware. Just bought the truck. Strikers looked in good shape, had a real thin nylon skin on the striker.But, sure would chatter when you hit a pothole. Not now.....its the simple fixes that are most gratifying.Dan
Old 09-25-2017, 10:26 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
I've been using thick wall 1/2" copper pipe on all my obs trucks for quite a while (over a decade) because it's simply what I have on hand.
Old 09-26-2017, 06:22 AM
rj1983's Avatar
rj1983
rj1983 is offline
I used a self amalgamating heat shrink tube that is commonly used in electrical work. Prior to that I purchased a set of the dorman strikers with the bushings however the diameter of the bushings was to large to allow the door to latch. Ended up getting my money refunded for that.
namxas
12-11-2014 07:24 PM
k-member
07-06-2011 11:44 AM
JoeVR5
17
02-16-2010 08:57 PM
todd jo
01-01-2010 09:33 AM
bchunter
Paint & Bodywork
01-03-2006 09:54 AM
Quick Reply: Door Striker Bushings
