Help, did some work, new squeal
This morning I finished up a few things on the truck, new starter, compressor wheel, gutted pedestal, up pipes, hpop hoses, o-rings along the way.
Got it started up and it sounded good, put it in reverse and I hear this awful screeching sound, I'm attaching a youtube video of it. It only does it in reverse with at least a slight bit of throttle, doesn't do it in drive. It will do it when moving as well as stationary with the brake held.
I don't think it's the compressor wheel rubbing as I stuck my head as close to the turbo as possible while the wife put it in reverse, it sounded lower. From underneath it seems to be on the drivers side, near as I can tell around the exhaust manifold. I did drive it for several miles. By the time I got back, it wouldn't make the noise anymore. I let it set for 8 hours and when I moved it this evening it's back to making a racket.
I just spent a while working on this thing and I'm not to eager to tear back into it, any ideas what to look for or where to start?
https://youtu.be/GwRIxSBiqdI
I messed around with the down pipe and couldn't get the noise to change, it has slightly rubbed on the heat shield underneath the truck before but it isn't now. It's pretty tight space where the drivers side up pipe turns up, but as far as I can tell it's not contacting there. To me it's just weird that it only does it in reverse?
Edit: Had a few minutes between work and evening plans, so I pulled that dust cover off. The squeal is still there
FIXED!!!!
The noise had reduced in intensity, but was still annoying me to no end, and I was embarrassed to drive the squealer. I checked the turbo shaft for play and to see if the compressor wheel was contacting, nope. Loosened and re-torqued the up pipe to manifold bolts, downpipe clamp, turbo to collector clamp, nope. Dust shield, nope. Removed the serpentine belt, nope. Spent quite a bit of time checking things over and pulling my hair out trying to find the source. This afternoon I decided to drop the new starter out and put my old one in. I don't see how in the world a starter could make that noise, but in desperation I swapped them and.... success!!!!!!! I'm feeling a whole lot better about the truck now, disgusting that it took so much frustration to find the cause. They're sending out a new denso style starter.
It's just unfortunate that I did a bunch of work at the same time, if I had only done the starter that would have been my top suspicion. Oh well, I'll sleep better tonight.
Kim_Wysocki
05-27-2017 04:40 PM
99stroke
1999 to 2016 Super Duty
05-20-2004 06:27 AM
