Hot Water Heater Expansion Tank
I just had the water heater replaced. The plumber suggested adding an expansion tank. I asked him why and he said the water expands when heated.
If the tank is directly connected to the municipal supply at 60 psi, how can there be a pressure buildup in the tank? It seems to me the water will expand back into the supply and 60 psi will be maintained.
What am I not getting?
Many municipal systems are installing back-flow preventers (check valves) in the supply laterals that serve each customer's premises. These valves are specifically installed to PREVENT water from flowing backwards to prevent potential contamination of the municipal supply. If your water company has done this, you NEED an expansion tank in your home. If you do not install one, the water system pressure will spike when cold water comes in, gets heated, and expands. If you're lucky, the T&P valve will "leak" and relieve the pressure. Many homeowners will see this and replace the T&P valve, sometimes several times, before they ask the right question of the right person.
In many jurisdictions around here where the check valves are in use, the addition of an expansion tank is mandatory (local code) with a water heater replacement or new installation.
If you're on a private well, this doesn't apply. Most private wells already have a pressure tank and no backflow preventer.
ranger1999 Bob
22
01-04-2010 01:58 PM
fred_79f250
11-04-2006 08:41 AM
