99 f250 superduty 5.4 engine rebuild help
Old 01-17-2017, 11:34 PM
APICTON12's Avatar
APICTON12
APICTON12 is offline
I have a 99 f250 superduty 5.4L with 270K miles. It runs great but really weak due to high miles. The only issue is a blown head gasket. There are no ticks or clanking noises it is very quiet and smooth. I want to pull the motor and buy a kit for a basic rebuild and replace all gaskets and things of that nature. The kit includes freeze plugs, pistons and rings, timing chain kit, rod bearings, main bearings and oil pump also full gasket set. I do not have the budget to purchase a new motor and my question is would this rebuild be worth my time. Basicaly will it make my motor run strong again. Any input or comments are greatly appreciated!
Thanks
Old 01-19-2017, 02:10 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
In short- yes.....but IMHO I would pull the heads 1st and mic/check the cylinders to see how far out-of-round they are....if less the .001, a hand operated cylinder re-groover will work just fine, if more than that, then its time to have a machine shop re-bore the block......
Old 01-19-2017, 04:18 PM
APICTON12's Avatar
APICTON12
I planned on boring the heads and shaving the crank shaft over .020 because I imagine there will be wear. But of course just like you said I am going to pull those parts and see how worn they are and if boring the heads and shaving the crank are even necessary.
quakerj
04-17-2014 06:49 AM
gator120
1997 - 2003 F150
01-31-2010 01:07 PM
Eagle460
05-30-2008 09:55 PM
notyettoday
09-29-2004 02:22 PM
BEAVER
10-28-2002 05:40 PM
Quick Reply: 99 f250 superduty 5.4 engine rebuild help
