Jump Starting with Dual Batteries
Stupid question - I've just never done it.
If I'm giving a jump:
Assume I hook positive and negative cables to the respective terminals of one of the two batteries. The alternative would be hooking positive cable to one battery and negative cable to the other battery, or does that make 24 volts? I'm also assuming if it is just the one battery, it does not matter which one you jump from?
If I'm receiving a jump:
I assume positive cable to positive post of one battery and negative cable to a good ground under the hood somewhere? Again, does it matter which battery I use? I wonder where a good ground is on this crowded diesel engine and aluminum body. Front radiator supports?
Thanks in advance.
Thanks in advance.
No, the batteries are in parallel. You will only get 12 volts hooking up to Positive on one battery and Negative on other battery.
Yes, receiving a jump, you should connect Positive to the battery and the Negative to a good ground. You can use the bumper as a good ground. Always hook Positive first then the Negative.
At one time, Ford manual said this:
JUMP STARTING YOUR VEHICLE
The 6.7 diesel engine can be jump started using the same procedure as a
gasoline engine. Use the primary battery (battery located on the
passenger side) for any jump starting procedure and refer to your
Owner’s Guide for the proper method of jump starting.
I believe that no battery is specified in the manual for late models.
Always leave the the vehicle giving the jump off. While manufacturers have come a long ways, vehicles electronics are not immune to voltage spikes caused by a second alternator coming to life and seeing a dead battery....
It's probably a valid point, but I've jump-started vehicles for years and always left the vehicle giving the jump running. In fact, sometimes had to rev the jumping vehicle's engine a bit to provide enough juice. Never had an issue.
reving the to push enough juice to the dead battery is because of small cables. Buy a good set and you won't have too.
Like this:
https://www.amazon.com/Energizer-1-G...+jumper+cables
Like this:
If the dead soldier won't fire with the good vehicle at first, go ahead and start it, take a coffee break, then shut off and repeat. I'd almost expect to have to do that if our trucks were dead and being started by a lessor vehicle.
American vehicles are most tolerant of it. German.....well....
