Does brake booster need replaced?
Old 01-16-2017, 12:53 PM
BigSexy78's Avatar
BigSexy78
BigSexy78 is offline
On my 79 when I push on the brakes the booster makes a noise which the easiest way to explain it is a farting noise. I have done the tests that I know of on it and it has passed all of the tests, pushing on the brakes then starting the engine and pedal goes down some etc. Could this booster still be defective causing my pedal to somewhat feel spongy?? I have seen elsewhere on the internet that a defective booster could make the pedal feel spongy but it did not come from a real reliable source. As much as I have bled the lines there is no way there is any air in the lines.
Old 01-16-2017, 01:29 PM
HoustonDave's Avatar
HoustonDave
HoustonDave is offline
Sounds silly, but maybe lube the pivot points on the brake pedal? If the booster shows no other signs of an issue, you know there is no air int he lines...the pedal seems like a possible culprit.
Old 01-16-2017, 01:42 PM
BigSexy78's Avatar
BigSexy78
Thank You but I have lubed the joints already. The noise sounds like it is coming from the bladder or whatever they call it.
Old 01-16-2017, 01:44 PM
78 PEB's Avatar
78 PEB
78 PEB is offline
I have heard them do this before........never checked out one that was doing it to know if the booster was bad or not.......
Old 01-16-2017, 08:59 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
To properly trouble shoot, if you hook a vacuum gauge to the supply and push pedal to 0 reading, then shut engine off, then hold at position, a kick back indicates vacuum leak. Good luck.
Old 01-16-2017, 11:53 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
Talking
So would you call it braking wind?
Old 01-16-2017, 11:56 PM
78 PEB's Avatar
78 PEB
78 PEB is offline
LMAO!!!!!!!!!!!
Old 01-17-2017, 12:07 AM
Big Green Machine's Avatar
Big Green Machine
Big Green Machine is offline
"Braking wind" - that's the funniest thing I've read all day
Old 01-17-2017, 07:03 PM
BigSexy78's Avatar
BigSexy78
Well I went ahead and replaced the booster today. So now there is one less thing making farting noises in the truck and according to my wife that is a good thing!
reno138
03-13-2014 08:12 AM
wickedklown83
07-08-2010 10:36 AM
backdraft341
06-08-2010 05:14 PM
azfordf100man
10-16-2007 12:12 PM
popeye69
01-30-2005 05:10 PM
Quick Reply: Does brake booster need replaced?
