Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1993 F700 hub cap part #
Old 01-15-2017, 08:09 AM
kpj's Avatar
kpj
kpj is offline
Haven't owned this truck for long and need to do some repairs before i can drive it. On of the problems at the moment is that the hub cap window on the drivers side is broken and leaking. I attached a picture so you can see what kind of hub cap it has. Problem is that i can't really go to local dealership and ask a new one, since these haven't been ever sold here. I've looked for one on the internet, but haven't found a correct one. It has Ford and Stemco stamps, but the hub cap has only 4 bolts, which have made my search a pain, since there is usually 6 attaching bolts. So do you know correct part # for the hub and maybe where i can buy one. Thanks!
F700 hub cap
Old 01-15-2017, 05:35 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
This is not a hub cap and I've never seen or heard of a hub cap window.
Where is the truck located? Your "About Me" profile says FI .. but I have no idea what country this abbreviation represents.
So, what's actually leaking, a front seal on the axle? Is it 4WD?
Old 01-15-2017, 07:20 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
This a wet hub. Used on trailers,bigger truck front hubs. The plug snaps out fill with what ever oil is called for. Most seem to use 85-90. The plug is avaible at truck/trailer shops. Bet napa carries them too. Truck / trailer supply carries Stemco.
Old 01-15-2017, 07:26 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
FI = Finland.
Is OP looking at:
Product Search | STEMCO
I suggest OP post a picture of the warranty/data plate from the drivers door. (these things changed from an embossed metal plate to a sticker at some point) I will have the VIN, GVWR, and transmission and the AXLE CODES on it. From the axle code, the hb cap info might be found. Might.
Old 01-16-2017, 10:57 AM
NumberDummy
Originally Posted by 85e150six4mtod
FI = Finland.
Is OP looking at:
I suggest OP post a picture of the warranty/data plate from the drivers door (these things changed from an embossed metal plate to a sticker in 1980).
It will have the VIN, GVWR, TRANS and AXLE CODES on it. From the axle code, the hb cap info might be found. Might.
The sticker (Certification Label) is composed of a clear outer layer, printed inner layer. The label got wet and...
Sooner or later, this could cause the outer layer to peel off, taking some/all of the inner layer along with it.
Old 01-16-2017, 11:07 AM
kpj's Avatar
kpj
kpj is offline
Thanks for replies ... Yep, from Finland and no Napa stores here to look for a replacement. Basically if you're not in to European cars or Chevy trucks, you're screwed trying to find parts. Here's the pic from the door sticker. If it's not too much trouble for you have the possibility to decode the vin, i would appreciate it. Hopefully it shows the correct hub cap for it also....
the winemaker
10-12-2017 04:53 PM
artfreeland
02-08-2014 08:13 AM
RCFORD
1999 to 2016 Super Duty
06-11-2007 03:26 PM
user 5363849
10-25-2003 10:47 AM
Quick Reply: 1993 F700 hub cap part #
