hub cap fix
Old Feb 4, 2014 | 01:15 PM
artfreeland's Avatar
artfreeland
hub cap fix
<a href="http://s148.photobucket.com/user/artfreeland1/media/IMG_20140204_101339_681_zps70030402.jpg.html" target="_blank"><img src="http://i148.photobucket.com/albums/s6/artfreeland1/IMG_20140204_101339_681_zps70030402.jpg" border="0" alt=" photo IMG_20140204_101339_681_zps70030402.jpg"/></a>
I put on new Mile Marker 449ss hubs on my Excursion last week. I hated the gap the I now had from the new hub to the cap. After a couple days of thinking about it, this is what I came up with. What do you all think? (IF a pic didn't show up, then I screwed up)
Old Feb 4, 2014 | 01:52 PM
WarX's Avatar
WarX
Looks good, now about some plati-dip in black
Old Feb 4, 2014 | 02:09 PM
Apocalypse's Avatar
Apocalypse
Looks great! Any before pics?
Old Feb 4, 2014 | 11:45 PM
EXv10's Avatar
EXv10
We give up, what did you do to it?
Old Feb 5, 2014 | 06:38 AM
fordboy67's Avatar
fordboy67
Details on what you did?
Old Feb 5, 2014 | 08:16 AM
ExploringNH's Avatar
ExploringNH
The factory hub caps have a very small lip on the inside. It looks like the lip was extended but I am curious to know how. It truly looks factory.
Old Feb 8, 2014 | 07:54 AM
artfreeland
sorry for the late response. One person asked "what is different". When you take off the stock lockouts and replace them with the MM hubs, there is a 1" gap b/t the new hubs and the hub cap. It drove me nuts (and only after about 3 days). I have looked up to see if anyone came up with an idea of filling the gap, I found nothing. what I did...
-went to Home Depot and looked at several different types of tubing. What I found is 3"x2" plumbing tube fit perfect inside of the hub cap. I measured the inside of the cap to the actual hub and found it to be about 3/4".
- I put the PVC in a vice and cut the 3" side to 3/4" (cut a little on the heavy side)
-took my neighbors dremmel tool and trimmed the edge at about 45 degree's(just makes it fit better in the groove)
-on the new 45 degree lip put a moderate layer of JB Weld (insert jokes/laughter here)
-place the 45 degree edge into the hub cap.
--looking into the (backside or inside..whatever you call it)hub cap place a heavey amount to JB Weld around the outside of the newly installed ring and smooth it out against the edge.
-spay it with chrome spay paint from the inside of the cap(looks better when dried).
-install the cap back on the truck.
Disclaimer:
I don't know how you guys fell about JB Weld...but I have found it to work amazingly well on many other applications. The cap and the new ring are non weight bearing, and it's plastic to plastic. I think that it looks great, and I know longer have that annoying gap.
sorry I didn't take before and after pics, I was so excited to see if my project was going to work!!
As far as the person who posted the pic with the Warn hubs....Is that a different cap from another model of truck? You don't have a gap on yours like I did?
I hope this helps others looking to upgrade your hubs.
Old Feb 8, 2014 | 08:04 AM
WE3ZS's Avatar
WE3ZS
Nice solution to the cap gap Art! Looks good, much better than the typical open gap. The other pic with the more shallow recess is due to the rim being a steel wheel vs an aluminum, they are thinner so there is less of a gap to fill.
Old Feb 8, 2014 | 08:13 AM
artfreeland
Thanks WE3ZS!! I appreciate the compliments!! The steel wheel vs the aluminum makes sense. When I saw that pic this morning of the steel wheel I was like the What the heck!!
anyhow, much appreciated.
Art
the winemaker
Oct 12, 2017 04:53 PM
ExtrmZ
Mar 18, 2010 10:28 AM
bass4163
May 9, 2008 04:30 PM
RCFORD
Jun 11, 2007 03:26 PM
sawfish99
Mar 23, 2006 11:18 PM
